Hi, I have a D9 SV and neither of the rear power windows will not work from the buttons on the rear doors. They work fine from the drivers switches. I have tried the child lock on drivers consul in both positions but it does not allow the rear windows to work. Have tried to clean inside child lock (pulled it out) with Mentholated spirits but no fix. Any clues re how to fix????
If the switch is faulty you could always grab one from a breakers.
To prove the point; if you've got a Haynes manual find the pins to the switch for the rear window override & bridge the switched connections. If they work, the switch is your culprit!
