Hey chaps,
Mot time came and had to spend quite a few quid to get it through.
The car does not seem to pull well through the gears, when you floor it in 2nd, thrid or 4th there is no real power at all and all I can hear is the whistle from the turbo.....or could it be a boost leak?
No, not slow (relatively speaking of course), at just over 3k it should be pulling like a train. Check for splits/damage in the pipework between the turbo, intercooler and inlet.
They can be diagnosed, but not much will work with them, (AFAIK), apart from Pug's own Peugeot Planet 2000 / Lexia 3 interface.
Clones available from Ebay, among others, for about £110. (beware of £80-ish ads for S1279 modules - this isn't the whole system, it's just an add-on for newer cars).
There's getting to be a few members with this kit now - may be worth adding your location in case anyone nearby can help.
I had these similar symptoms but maybe not as noticeable as yours. It was diagnosed on an ECU reader - P0165 if I remember correctly - needle lift sensor dead. Replaced and it was as good as new.
Does sound like a split hose/pipe somewhere, 2.1TD's are quite quick, especially if chipped
