Wanting to give my 2.1 TD a service today, oil and filters arnt a problem etc, I'm just a bit hesitant on changing the fuel filter, Is it easy to do on the 2.1?
Only reason I ask, is I once changed the fuel filter on a diesel Zafira and I could'nt get it started afterwards, it took 2 days of faffing and towing it around the block to get it going again
the 2.1 is suposed to be the best, idont know tho, never driven one,
as of the Filter change, ithink itd be acase of just priming it afterwards,
hopefully someone will confirm,
Well if u cum usc u can have a drive of mine and yeh wen u change it just pump the bulb b4 u try starting it it should be fine
Yeh some of them are like that I've got 2 and it depends on how its been driven in its life I've had just under 130 out of mine witch is good for a 15 year old car
