clutch problem 1998 sx 1.9td est
- 1.8 8v
d
- 2.0 Turbo
Re: hi i wasnt sure where to put this
first thing to check is if the clutch is hydraulic or not and check all the cables for tight bends and kinks, there is an adjuster on the acc cable near the pump end.
is the clutch is hydraulic then you may have to bleed the system or replace the master and slave cylinder
- 1.8 8v
okay thank you i will try and find out i got to buy a service manual soon the owner manual says its a be3/5 clutch if that makes any sence to you im un experienced when it comes to mechanics.
- 2.0 Turbo
Re: clutch problem 1998 sx 1.9td est
had a look and it's a cable so replace the cable
euro car parts have clutch cables in at under £30
If you've got ramps or axle stands it's a fairly straight forward job, failing that parking with the drivers side wheel on a kerb will do in a pinch as long as you're not blocking traffic.
Never work under the car on the silly scissor jack that's for changing wheels at the side of the road only.
Being extremely careful it shouldn't take more than 1 1/2 hours less than 1/2 that once you know what you're doing
From the pedal clip it goes to a gromet through the bulk head then a couple of clips in the engine bay then slots into the clutch lever, hardest part of doing mine was hooking the stupid clip on the back of the clutch pedal! having 2 elbows on each arm helps.
It's an auto adjusting cable so just keep pumping the pedal once it's assembled and it's job done.
Any concerns just take lots of pics of the old one for reference.
2003 2.2 HDI SE
2003 2.2 HDI SE
- 1.8 8v
wow thanks guys i shall do i got manual on order so i can use it as reference as im new to mechanics. i lost a mate to a car falling on top of him so im well up on saftey
i know to always stick the spare wheel under the car just and case i shall have a look to be extra safe im gtoing to get wheel ramps im glad its not a problem which will involve replacing the clutch the pedal does seem to be getting better first peugeot ive owned so getting used to the clutch. it does have a very high biting point thank you for helping me out appreciated
- 1.8 8v
