1.8 16 vavle misfire
- 1.8 8v
Any advice welcome please
1996 1.8l 16v has suddenly developed a hesitation / misfire mainly during acceleration most noticable around 2000 revs, cruises ok and idles ok.
Changed plugs as first step. But no luck.
Partner said it began when she put petrol in yesterday. Was wondering if it might have been some dodgy petrol. Have put more petrol in today and give it a good run but not improved it.
Bit puzzled now.
Thanks for any help.
Bit puzzled now.
- lozz
Re: 1.8 16 vavle misfire
It couid be anything so it be hard to guess,
Fuel filter,
Or coil pack failing perhaps.
Fuel filter,
- 1.8 8v
Noticed its not doing it this morning from cold start. Began missing and hesitating as it got warmed up.
A friend who used to work at peugeot garage said coil packs on these didnt fail much at all.
- Site Admin & Mad Biker!
If it's of any help many moons ago I had the exact same year/model/engine with the same intermittent missfire and it was the coil pack!
- 1.8 8v
Begining to think coil pack myself. Just got one of the bay
Fingers crossed
Fingers crossed
Coil packs on these fail all the time. They develop small cracks in the plastic and as moisture gets in you get exactly the fault you describe.
Here's how you fix it:
Take of your coil pack, and locate the cracks. Spray a liberal amount of crc/wd-40 in there. Use either an airgun or a can of compressed air to blow it clean. Repeat a couple times. Seal of the cracks with Tec 7 or something similar. Enjoy.
Also these cars are pretty forgiving when it comes to bad fuel. I accidentally had half a litre of water in my fuel (don't ask), and after about 10 minutes of start-stop and turning it came back to life and has ran as clockwork ever since. Didnt even change the fuel filter.
Land of the Free?
- lozz
Good info there mate,
IMHO, you can repair them. but its best to replace them
I've used hareldite or a smear of Vaseline stops them a rkin out.
But the heat of the engine breaks them down again
Alright as a temp measure tho
- 1.8 8v
thanks for the info everyone, the car is getting on a bit 16 yr old
is this the same coil pack you refer too?
Yep that's the onecrad2 wrote:thanks for the info everyone, the car is getting on a bit 16 yr old
- 1.8 8v
Coil pack has cured it. thanks all.
Excellent news!
