gear oil leak
loadlugger
gear oil leak
Post by loadlugger »
After changing the clutch on my 1.8 petrol,there seems to be a bit of a leak,and it seems to be coming from the half moon shaped tin plate on the bottom of the box on passenger side,the piece where there is a couple of 11mm bolts holding it.Any ideas folks.
Re: gear oil leak
The tin plate you can see here, next to the exhaust pipe? (pic from a V6)
if so, then if it's definitely gear oil (who can mistake that smell...) I'm afraid you're in for bad times. The oil leak will be from this:
which is the oil seal from the gearbox to the bell housing which is what the clutch release bearing slides on:
However, if you're unsure about the smell, it MAY just be the case that you've knackered the (rather brittle) slave cylinder, which on a D9 is only about £20. Or it could also be the bottom end bearing behind the flywheel.
If you do need to remove the gearbox, I *strongly* recommend a new release bearing to save yourself needing to do the job a third time
markw
Re: gear oil leak
Post by markw »
......and fit new diff seals as well.
Hopefully your fix won't be a drastic as this.
loadlugger
Re: gear oil leak
Well its definatley fresh gear oil,and car is a p reg d8 model,and also is cable operated clutch.
Re: gear oil leak
Crap :( In that case there's nowhere else it could come from but the collar pictured above. I'm so sorry :(
loadlugger
Re: gear oil leak
Oh well gearbox out again then it is :x ,but thanks for the replies anyway peeps. :)
