Squeak Clutch
Squeak Clutch
Hiya,
My clutch has developed a squeak sound when i press down on it, the noise also seems to come from teh gear knob, ominous signs of something serious???
406 110 HDI 2002 estate
Re: Squeak Clutch
Pass
Try squirting some WD about?
Re: Squeak from Gearbox???
The squeak is not coming from teh clutch but its coming from the gearbox when i change gears???
Re: Squeak Clutch
pop the linkage ball joints off the top of the gearbox - work out whether the squeak's coming from the linkage or gearbox
Re: Squeak Clutch
A bit difficult to do that as the sound only occurs when i drive the car.
Re: Squeak Clutch
erk! What if you put it into 5th and slowly let the clutch out with the handbrake on?
Re: Squeak Clutch
Tried that and as expected the car stalls.
Re: Squeak Clutch
duh... but does it squeak?
Re: Squeak Clutch
Hiya,
No it doesn't
No it doesn't
Re: Squeak Clutch
I have no idea.
