Need codes read - 2.1TD power loss
sixspeed
Re: Need codes read - 2.1TD power loss
Post by sixspeed »
Well the car drove OK for a few days but then the problem came back :cry:
Did you check the strainer in the tank?
sixspeed
Post by sixspeed »
Not yet, I'll have a read up on how to do it...
It's dead easy, just lift the back seat, driver's side & there it is. It's do-able in half an hour or so.
ye it sounds like it could be that, if it drove ok for a few days. .
sixspeed
Post by sixspeed »
I found a local garage who were happy to read the codes for free (up yours Peugeot!).
They cleared the codes, then checked again following day and only fault present was:
'brake & accelerator pedal inconsistant' (or words to that effect)
It has led us to the conclusion that the brake pedal switch may be faulty, fooling the ECU into thinking that they're both pressed simultaneously (I managed to replicate the fault by revving in neutral and pressing the brake). So for the sake of £7 I've bought a switch and will fit it as a trial. Trouble is it sounds very awkward to get at! Any tips (or should I give up now take it back to the friendly garage).
BTW the friendly garage are Liphook Motors in Aldershot, recommended by H&H nearby.
omega
Post by omega »
sixspeed wrote:I found a local garage who were happy to read the codes for free (up yours Peugeot!).
its simple
all
you have to do is hook your feet over the back of the seat and stick your head down by the pedals hold a torch double joint your arms and its done.
