Noisy HDi Engine :(
Noisy HDi Engine :(
Just seemed to happen tonight, but a m8 said it sounds very rough, like tappets or something.
Any idea what could be the cause? Its due for a service now, but aint got the cash for that until a few mths time.
Vehicles I own:-
Vehicles I own:-
- xplosiv
re
Hi,
On getting my pug hdi serviced, it was suggested that i get the bottom crank pulley changed ( as i was getting a cambelt change ), but could not afford it, i asked the pug dealer when i should get it changed and/or when i know if it needs changing, he said when you hear a knocking noise.
This may be the problem ( have no idea about the HDI engines), but any question about the nice simple old DT engines i can answer
Many Thanks,
Andy
Many Thanks,
Andy
Its actually overdue 200miles for a service, so last oil change would be about 8,000 miles ago (its done almost 119k. So I know it needs doing, but lack of funds atm, need another 4-8wks b4 I can afford it, altho I could afford an oil change and get a m8 to do it. I went back out in it last nite, and it sounded ok to me, def quieter than it was. It was actually Trem1's son who told me it was fooked last nite when I pulled into the car park. Gonna get a m8 to check it out today, and poss take it to a garage I know. Garage is part of the local cruising forum, so I know there will check it out and lmk what is what with little/no cost to me unless it needs repairs.
Vehicles I own:-
Vehicles I own:-
miniman wrote:The bottom pulley is the problem here me thinks. Mine has a weird metal shim/ring in it that made a noise, so I pulled it out and its fine now.
I caked my pants when I heard it first!
Is this what you mean?
Pulley Failure
If the pulley separates and the belt falls off then fine, but if it separates and gets all wrapped up in a mess near the cam belt end thats not so good.
Pulley Failure
Yep, thats it, but the shards of shim doesnt come from where his arrow is showing, it comes from round the rim. Im going to remove the pulley at the weekend and effect my own repair. (I am an engineer/ tight arsed Scot after all!)
I will advise better on the situation on Monday, but no way am I paying 120 quid for a pulley!!!
2002 Black 406 Executive 2.0HDi
Been down local Garage and recons its the Bottom Pulley, should know for certain 2mora when he has a proper look at it. ?70-?90 if it is.
Vehicles I own:-
Vehicles I own:-
What's it sound like then Geordie?GeordieBoy wrote:Been down local Garage and recons its the Bottom Pulley, should know for certain 2mora when he has a proper look at it. ?70-?90 if it is.
Its like a loud tapping/knocking noise coming from the engine, bottom pulley also looks a little wobbley as well. Thats the 1st thing I looked at last nite.
Vehicles I own:-
Vehicles I own:-
As if I would do that.trem1 wrote:you could try noy revving to the limiter quite as often![]()
Vehicles I own:-
Vehicles I own:-
Can you record it matey for here ?GeordieBoy wrote:Its like a loud tapping/knocking noise coming from the engine, bottom pulley also looks a little wobbley as well. Thats the 1st thing I looked at last nite.
