HELP TOTAL SEIZURE!!!!!!!!!!!!!!!!!!!!!!!!!!!!
my cars f*cked. I was out today on a day out with the family driving in the countryside without any problems until i deciced to drive through a ford(you know small river type) water was about six to ten inches deep so not too bad i thought, two thirds of the way through car started acting up just as i was emerging there was a strange clicking noise and no power at all. engine stoppes twice which i restarted but didnt sound right very strange clicking not vroom vroom noise then it stopped and it now just clicks as if starter stuck.i tried putting it in 2nd gear and rocking it back and forth its seized solid .it showed no signs of a problem as in no warning lights ,no high temperature nothing but it appears to be seized solid
any ideas
would be great
cheers lads
any ideas
would be great
cheers lads
- niz406
- Admin <BR>Turbo God
- niz406
Take it to Blingmotors, Steph will do his best to sort it at the cheapest possible price. LMK if you need a tow anywhere, I will help. I think you have my mobile, if not just PM or will see ur Kev tues/thurs.
Vehicles I own:-
Vehicles I own:-
no checks made because the cars stuck in a field about 40 mile or so away from home, thought about getting a tow of my son but he only got a 1.1 206 so it would probably kill that as well, all i can do is keep my fingers crossed and get it home as soon/cheap as i can
god i hope none of you lot ever feel as bad as i do right now
- niz406
I dont mind towing it for ya, or give Steph a ring @ J&S Autos (Blingmotors, washington) he has a tow truck on 24 hr call.
http://www.jsautos.blingmotors.co.uk
Tel: (0191) 417 5222
Mob: 0777 6181256
Mob: 0776 6004358
Mob: 0777 6181256
Mob: 0776 6004358
Vehicles I own:-
Vehicles I own:-
Nope I aint got a tow bar, but they must be something I can fasten it onto.
Hope you got a tow rope cos I aint.
Vehicles I own:-
Vehicles I own:-
- Foghorn Leghorn
- Davva2004
- Location: Stood beside my 406 with a sledgehammer, cursing everything French
Take off the coil pack and take out all the spark plugs, then turn it over on the starter motor... if it won't turn over that way, you have a major mechanical failure and it's rebuild time. If it will turn over, put some clean rags down the spark plug holes and crank it for a while to soak up as much water out of the cylinders as possible, then refit plugs and coil pack and keep trying to start it. It'll take a while but eventually it'll run on all 4 cylinders.
Get it home, then immediately do an oil and filter change cos your oil will be contaminated. The service centre which is part of my local Hellfrauds did me a 15W40 semi-synth oil and filter change for £36.50 last week when I gave mine a service so it's not too expensive.
