Fault code P0230
Fault code P0230
The engine management light came on displaying anti pollution fault yesterday and the car went into limp mode gave me upto about 2500 revs per gear, as i tried to get home the engine would cut out. If you left it 5 seconds it would restart and i could continue.
I got it to a friend who is a mechanic and with a reader had the code P0230 showing. After a bit of playing the EM light went out and the car ran fine for 100 miles then back to the above. Also when you turn the ignition off the engine runs on for a few seconds before stopping
This it seems is a Fuel Pump Primary Circuit Malfunction.
In Jan the pump in the fuel tank failed and was replaced with a new one. Since then the car has run no problems at all, this week the seal on the top of the tank went so this has been replaced, sadly 1/4 tank of diesel split out overnight onto the road!!
There does not seem to be much of a mention on this site for this code so i was wondering while i wait for monday so i can get the car to a mechanic if anyone has come across this problem before.
The car is an 01 Y 406 hdi 110 estate New pump was a Bosch
thanks in advance
thanks in advance
2001 406 HDI 110 GTX Estate
- lozz
Re: Fault code P0230
Hi,
From what ican see P0230 is a Fuel Pump Primary Circuit Malfunction
thats all ican see on a fault code list, hope it helps if any,
edit sorry didnt read post properly thought you was looking to see what the fault code ment
ive seen this from another source it might be worth a read
Fault code P0230 points to a faulty fuel pump relay. You need to check that the fuel pump in the tank is working and sending fuel up to the engine at good pressure. It sounds like the relay is shutting off and the high pressure pump on the engine is drawing fuel through until you let it idle then it can't draw enough and so cuts out. The relay is called a 'relay module' on this car.
Check fuses 22, 24, 25, 26, 27, in the engine compartment fuse box first. Fuse 25 must be at least 15 amps.
If this all checks out, the fuel pressure regulator is on the end of the pump, not the unit on the top. If you remove this and switch on the ignition - DO NOT TRY AND START - the low pressure pump should force fuel out of the pump here.
Heres the list of codes,
P0200
Injector Circuit Malfunction
P0201
Injector Circuit Malfunction - Cylinder 1
P0202
Injector Circuit Malfunction - Cylinder 2
P0203
Injector Circuit Malfunction - Cylinder 3
P0204
Injector Circuit Malfunction - Cylinder 4
P0205
Injector Circuit Malfunction - Cylinder 5
P0206
Injector Circuit Malfunction - Cylinder 6
P0207
Injector Circuit Malfunction - Cylinder 7
P0208
Injector Circuit Malfunction - Cylinder 8
P0209
Injector Circuit Malfunction - Cylinder 9
P0210
Injector Circuit Malfunction - Cylinder 10
P0211
Injector Circuit Malfunction - Cylinder 11
P0212
Injector Circuit Malfunction - Cylinder 12
P0213
Cold Start Injector 1 Malfunction
P0214
Cold Start Injector 2 Malfunction
P0215
Engine Shutoff Solenoid Malfunction
P0216
Injection Timing Control Circuit Malfunction
P0217
Engine Overtemp Condition
P0218
Transmission Over Temperature Condition
P0219
Engine Over Speed Condition
P0220
Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221
Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
P0222
Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223
Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224
Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225
Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
P0226
Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
P0227
Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228
Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229
Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P0230
P0231
Fuel Pump Secondary Circuit Low
P0232
Fuel Pump Secondary Circuit High
P0233
Fuel Pump Secondary Circuit Intermittent
P0234
Turbocharger Overboost Condition
P0235
Turbocharger Boost Sensor A Circuit Malfunction
P0236
Turbocharger Boost Sensor A Circuit Range/Performance
P0237
Turbocharger Boost Sensor A Circuit Low
P0238
Turbocharger Boost Sensor A Circuit High
P0239
Turbocharger Boost Sensor B Circuit Malfunction
P0240
Turbocharger Boost Sensor B Circuit Range/Performance
P0241
Turbocharger Boost Sensor B Circuit Low
P0242
Turbocharger Boost Sensor B Circuit High
P0243
Turbocharger Wastegate Solenoid A Malfunction
P0244
Turbocharger Wastegate Solenoid A Range/Performance
P0245
Turbocharger Wastegate Solenoid A low
P0246
Turbocharger Wastegate Solenoid A High
P0247
Turbocharger Wastegate Solenoid B Malfunction
P0248
Turbocharger Wastegate Solenoid B Range/Performance
P0249
Turbocharger Wastegate Solenoid B Low
P0250
Turbocharger Wastegate Solenoid B High
P0251
Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252
Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253
Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254
Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255
Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256
Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257
Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258
Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259
Injection lump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260
Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261
Cylinder 1 Injector Circuit Low
P0262
Cylinder 1 Injector Circuit High
P0263
Cylinder 1 Contribution/Balance Fault
P0264
Cylinder 2 Injector Circuit Low
P0265
Cylinder 2 Injector Circuit High
P0266
Cylinder 2 Contribution/Balance Fault
P0267
Cylinder 3 Injector Circuit Low
P0268
Cylinder 3 Injector Circuit High
P0269
Cylinder 3 Contribution/Balance Fault
P0270
Cylinder 4 Injector Circuit Low
P0271
Cylinder 4 Injector Circuit High
P0272
Cylinder 4 Contribution/Balance Fault
P0273
Cylinder 5 Injector Circuit Low
P0274
Cylinder 5 Injector Circuit High
P0275
Cylinder 5 Contribution/Balance Fault
P0276
Cylinder 6 Injector Circuit Low
P0277
Cylinder 6 Injector Circuit High
P0278
Cylinder 6 Contribution/Balance Fault
P0279
Cylinder 7 Injector Circuit Low
P0280
Cylinder 7 Injector Circuit High
P0281
Cylinder 7 Contribution/Balance Fault
P0282
Cylinder 8 Injector Circuit Low
P0283
Cylinder 8 Injector Circuit High
P0284
Cylinder 8 Contribution/Balance Fault
P0285
Cylinder 9 Injector Circuit Low
P0286
Cylinder 9 Injector Circuit High
P0287
Cylinder 9 Contribution/Balance Fault
P0288
Cylinder 10 Injector Circuit Low
P0289
Cylinder 10 Injector Circuit High
P0290
Cylinder 10 Contribution/balance Fault
P0291
Cylinder 11 Injector Circuit Low
P0292
Cylinder 11 Injector Circuit High
P0293
Cylinder 11 Contribution/balance Fault
P0294
Cylinder 12 Injector Circuit Low
P0295
Cylinder 12 Injector Circuit High
P0296
Cylinder 12 Contribution/Balance Fault
P0298
Engine Oil Over Temperature
P0200
P0201
P0202
P0203
P0204
P0205
P0206
P0207
P0208
P0209
P0210
P0211
P0212
P0213
P0214
P0215
P0216
P0217
P0218
P0219
P0220
P0221
P0222
P0223
P0224
P0225
P0226
P0227
P0228
P0229
P0230
P0231
P0232
P0233
P0234
P0235
P0236
P0237
P0238
P0239
P0240
P0241
P0242
P0243
P0244
P0245
P0246
P0247
P0248
P0249
P0250
P0251
P0252
P0253
P0254
P0255
P0256
P0257
P0258
P0259
P0260
P0261
P0262
P0263
P0264
P0265
P0266
P0267
P0268
P0269
P0270
P0271
P0272
P0273
P0274
P0275
P0276
P0277
P0278
P0279
P0280
P0281
P0282
P0283
P0284
P0285
P0286
P0287
P0288
P0289
P0290
P0291
P0292
P0293
P0294
P0295
P0296
P0298
have a look here.....
http://www.ilexa.co.uk/forum/
Select Peugeot/Citroen and put the p0230 code in the search bar.
Maybe have a good look through the Peugeot/Citroen section.
Tony,
I have the exact same problem you described 12 months ago on my Y/2001 HDi 406.
Did you find a resolution?
Any advise would be appreciated.
Cheers,
Tom
Cheers,
Tom
406 - 2.0 HDi (90 bhp) - 2001 (Y) - Saloon
Hi guys,
Can anyone help me out identifying the model and part number etc of the Fuel pump in the photo attached. Can't make sense of it!
Cheers,
Cheers,
I am also having this problem at the moment, almost identical to Tony's post, has anyone found out what the cause of this is?
2000 2.0 HDI Estate GTX 90 bhp
no obvious sign of any water leaking on anything, i'll have a closer inspection at the weekend
