2.0hdi 110 gearbox removal
gez44
Post by gez44 »
This topic appears on here quite a lot .Can anyone tell me if it possible to remove the gearbox out of a peugeot 406 2.0 hdi 110 without dropping the subframe totally down .Is there an easier way of doing it as it looks quite tight for room
Thankyou :?
pgascoyne
Re: 2.0hdi 110 gearbox removal
Post by pgascoyne »
Looks like you need to check out this excellent post from MJB about changing a clutch which should just about cover all the info you'll need.
viewtopic.php?f=10&t=8234
Paul Gascoyne aka Gazza
406 RED LX HDI 110 W Plate
jasper5
Post by jasper5 »
pgascoyne wrote:Looks like you need to check out this excellent post from MJB about changing a clutch which should just about cover all the info you'll need.
Be aware that this excellent article is for the V6 engine, not the 110 HDi.
The last time I helped change a clutch on a 110 HDi we didn't remove the subframe. I think we may have lowered it slightly, but we didn't remove it.
gez44
Post by gez44 »
Thank you for the advice going to tackle it this weekend should be fun :wink:
