Had the Remap!
Had the Remap!
Had the remap done on my 110 on Friday,much livelier car all round now.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Had the Remap!
Come on then - who, what, how long, how much and, er, how much?
Re: Had the Remap!
Angel Tuning in Cropedy nr Banbury,took about an hour,and was £160,normally £190 but i had a discount voucher that i had bought before xmas.I wanted it doing because i want to tow a caravan with the car.steve_earwig wrote:Come on then - who, what, how long, how much and, er, how much?
Re: Had the Remap!
Sounds reasonably priced, especially if you're well pleased with the results.
Did they quote you any output numbers?
Re: Had the Remap!
They said 35bhp and 50lbft torque,i'd like to have had a rolling road output test before and after but couldn't find anywhere local to me that could do that so i'll have to take there word for claimed output,it really does pull quicker/better from 1500-3000 rpm.
Re: Had the Remap!
Nice one but keep an eye on the rear lower engine mount - it'll get mullered with the extra power and affect other stuff like the eggsauce flexi and whatnot.
Re: Had the Remap!
Just bought an orignal pug bottom engine mount from fleebay for £12 so i'm ready
,don't fancy changing it though
- puggy
- Resident Pervert
Re: Had the Remap!
Welly's words of wisdom !! how very true young man , mine is ready for another not sure ifWelly wrote:Nice one but keep an eye on the rear lower engine mount - it'll get mullered with the extra power and affect other stuff like the eggsauce flexi and whatnot.
it is second or third
links
And you were warned those handbrake turns would end in tears
Re: Had the Remap!
Bit of a pattern there, puggy.puggy wrote: mine is ready for another not sure if
it is second or thirdalso just had 2 front wheel bearings 2 strut top bearings and 2 drop
links![]()
Maybe you should let some of the Audi drivers go without the demo occasionally?
- puggy
- Resident Pervert
Re: Had the Remap!
- Bailes1992
Re: Had the Remap!
The boys in work take the piss because I crawl over the speed bumps leading upto site.puggy wrote:![]()
Smart ass !!
its the bloody speed humps i tell you
They won't be laughing when they are replacing bits of suspension
Glad your happy with the remap Brett! You didn't seem so sure when you popped down on Saturday!
Re: Had the Remap!
Well did over 300 miles this weekend after the remap and quite impressed so far.It was mostly motorway although my journey from oxfordshire to derbyshire fri night was just one traffic jam to another so a lot of idling in traffic.It pulls a lot more lively from 1500 rpm to 3000 rpm and overtaking on b roads is a lot more relaxed and less a white knuckle ride.The one thing i have really noticed is the improved mpg,i reckon i must me getting 5-8 mpg more than before,i'm seeing figures on the mfd i haven't seen before!
- Captain Jack
Re: Had the Remap!
I found the same with regards to the MPG figures being higher on the MFD but in actual fact, it hasn't really changed. Not sure how the MPG is calculated by the ECU but it seems that it might not take the extra fuel input provided by the remap into account. And because your foot doesn't need to be as heavy, it thinks you're using less fuel.
How's the smoking when booting it? Also, watch out for the clutch slipping as mine now is....
Re: Had the Remap!
I didn't notice any effect on the accuracy of the mpg on mine, (or for that matter any real change in mpg), 'cept if you get carried away - it can defo burn more of the stuff!Captain Jack wrote:I found the same with regards to the MPG figures being higher on the MFD but in actual fact, it hasn't really changed. Not sure how the MPG is calculated by the ECU but it seems that it might not take the extra fuel input provided by the remap into account. And because your foot doesn't need to be as heavy, it thinks you're using less fuel.
Mine doesn't smoke to speak of, no clutch slip & now no vibration at 2000 RPM.How's the smoking when booting it? Also, watch out for the clutch slipping as mine now is....
Re: Had the Remap!
No noticable increase in smoke,it had a replacement clutch and solid flywheel 5k miles ago just before i bought it so hopefully i won't have any issues with that.I will do a fill to fill calculation when i can afford to fill it up,i know what you mean about throttle position though as it seems you hardly have to touch the accelerator now when cruising 60-70 mph.
