Can anyone tell me if air con compressors are interchangeable?? I've got a 02 D9 estate and been offered one from a 03 D9 estate.
Cheers Paul
Air Con Compressors Interchangeable??
2002 110 LX ESTATE
1989 SUZUKI GSXR 711
Re: Air Con Compressors Interchangeable??
The big question is are they Sanden or Delphi compressors, they fitted both. And the buggers hidden away making it difficult to see. If you can get some pictures of yours, ideally from underneath, we may be able to tell.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
- lozz
You can tell by the label on them.
/SANDEN 01209807260 R134A 9646416780...
\ DELPHI 5290 SAE J639 1135290 100501249..
iirc the the sanden as a Small square Blue-ish turquioish feck knows how you spell that
label
and the delphi has along lable, yellow and green,
you shouid be able to spot the label perhaps a wipe with a rag will reveal it
- lozz
see: delphi http://www.ebay.co.uk/itm/PEUGEOT-406-2 ... 231f3370d6
sanden: http://www.ebay.co.uk/itm/peugeot-406-2 ... 2573aa6423
The pulleys are differnt,
- OdinEidolon
Pay attention, also they fitted several different Sanden for different years, most of the times they are interchangeable, but sometimes won't.
Learned this on my skin - servicebox had the wrong compressor for my VIN!
- lozz
The fan belts are different lengths for the delphi and sanden compressors,both are six rib belts just different lengths,so in theory with the right belt the compressors are interchangeable,unless any of the mounts or pipe connections are different?
Paul
Paul
2002 110 LX ESTATE
- OdinEidolon
Dunno for the 2.0, but in case of the 2.2HDi different compressors numbers may also mean different pipe mountings and electrical connectors.paulm wrote:The fan belts are different lengths for the delphi and sanden compressors,both are six rib belts just different lengths,so in theory with the right belt the compressors are interchangeable,unless any of the mounts or pipe connections are different?
Paul
The compressor pipe fittings are very different between the two. You will need to get the right one, it's a case of getting down there and having a look.
