wierd noise when pressing clutch 2001 406
Hi,
new to this so take it easy lol
i have a 2001 model 406 2.0l rapier diesel, the problem i have started a few weeks ago...
whenever i press the clutch or hold it down say when im sat at a set of lights or something, i hear a noise like a loudish rubbing noise its really annoying, at 1st i thought my clutch was on its way out but its been about a month now and its not even slipping so im now clueless as to what it could be, its not really really loud but loud enough to hear clearly when window is down!!!
the only way i can explain the noise is it sounds like something is spinning quite fast and every half a spin or so it makes a scraping noise... forgive for the scetchy explaination but like this....
(cchhh--------cchhh------cchhh---------cchhh--------cchhh---------cchhh--------cchhh) only when clutch is pressed tho :-( just had 12mths mot too :-( jest need a few oppinions as i no if i took it to a garage they would say new clutch straight away but i think its something else as its not slipping,....
help please..............
Re: wierd noise when pressing clutch 2001 406
Hi there, welcome
Umm, before we start scaring you, is this a 90bhp or a 110?
well it's the release bearing or the dmf , the dmf is fitted to the 110 only
if you are local to me i can have a look at it
i am in Sheffield, Yorkshire
Hi it's the 90bhp model... I think lol never really read much into it I was given it by
My dad 1 year ago it has 174,056 miles on the clock an just passed mot :-) running
Perfect apart from that noise when I hold the clutch pedal down :-@
I live in Chester so I'm quite far away :-( .... It's the only non electrical thing that's gone
Or going wrong since iv had it lol... Pretty annoying.. What do I expect now???
A week ?? a month or 2 left till what happens when it goes?? Thanks again...
But luckily the clutch hasn't started slipping yet... Will that start to happen or will I loose all
Drive ??
Drive ??
well its failed so it will eventually seize and rub on the fingers of the spring and they will snap, then you will have no clutch and will have to replace the lot. replace it now as its just the release bearing it will be cheaper then a new clutch
I thought it'd be wise to ask
If it eats through the diaphragm spring then the clutch won't release (bin there...). Seeing as how the gearbox has to come off to replace the bearing it'd probably be wise to replace the clutch while you're there (unless you know it's almost new).
You make it sound like your car has masses of electrical problems
What else is wrong with it?
at 174k, if it's still on its original clutch then it'd be foolish to not replace it along with the bearing
Hey guys...
Thanks for all the feedback so far... Yeah it's still on its original clutch at 174k lol and touch wood it's original battery :-) as far as elec probs go only front passenger window works and had a few warning lights on dash but only 1 that's on now is airbag and I no that's a prob under drivers seat so il leave that be for now... Iv done a bit of digging and the clutch comes as a 3 price kit with the bearing being 1 of the peices ???? So do you think having to replace it all anyway I might as well just wait till it goes??? Might get a few weeks or months out of it yet??? Fingers crossed... Typical as iv just forked out £350 to get it through its mot lol.. :-(
no you can buy the release bearing separate, any good parts shop will be able to get one for you
hears a genuine one http://www.ebay.co.uk/itm/CLUTCH-RELEAS ... 5642e323c3
i can check the part number if you pm me the last 8 digits of your vin
I would If I wasn't warm tucked up in bed haha
With it being on its original clutch and on 174k would it just be wise to wait for it to go and replace it with the 3 piece clutch kit it costs £110 plus labour so whilst they have the box off it might as well be done at the same time?? And on a guess will it last 2weeks till pay day??? Lol
Thanks guys
Thanks guys
The trick to making it last is to use it as little as possible. Don't make unnecessary journeys. If you're not brave enough to change gear without the clutch, you can at least save some wear & tear by slipping it into neutral when slowing down, then you only need one clutch operation to move off again. Avoid holding it on the clutch at junctions.
- Captain Jack
Obviously, if you do most of your journeys on a motorway (or some other clear, long road), then it will last a lot longer than inner city driving every day.
But yeah, replace it. Chester - jasper5 isn't far from you in Manchester. He's done several clutch changes on this forum, mine included (despite it still being relatively serviceable). Feels like a new car - do it.
Any idea how much I'm looking at for clutch kit and labour???
well i would charge £250ish for clutch and fit
euro car parts have a 25% discount on clutch kit
