Wiper stalk
Wiper stalk
Is there such thing as a D8 steering column wiper stalk for cars with rain sensors, with rear wiper control AND a trip computer button?
I got the guy at the stealer to have a look for me, but he couldn't see one
Spent 3 hours this morning trying to figure out what that button must do, to no avail :( If anyone's got a detached stalk with a t/c button and a multimeter to hand, I'd be grateful if you could poke at it...
jameslxdt
Post by jameslxdt »
it puts an earth down to the top 15 pin plug of the trip computer, not sure what pin though
Haynes says pin 5 (which comes out at 12v). Blown fuse says 'nope'
jameslxdt
Post by jameslxdt »
well, when i fitted my computer, i took out the sport suspension blank, next to the heated rear window switch, changed it for another heated rear window switch, but took the cover off the blank, and swapped it for the one on the new heated rear window switch, took an earth off the hazard switch and ran it through the modified heated rear window switch, so it looks like a blank, but you push it and it changes the function of the trip computer :P
ooh good idea! I just had a microswitch elegantly *cough* blu-tacked to the top of the steering column ;)
What 'mode' do you have the comp set to? (the little dial on the side)
1: Temperature in top-right, with proper "degrees c" symbol
2: Temperature in top-left in chunky letters, zero and below comes out as "LC", some sort of trip counter to the top-right and a picture of a car and a post to the bottom right
3: as 1
4: blank
I'm guessing '2' is the biz...
jameslxdt
Post by jameslxdt »
ive got an aftermarket cd player so mine is set to 2, but if you have the standard pug unit you have to use 1
600 miles a week without mp3 goodness? No mate, I've not got the standard head :)
Do you know what the difference is between 1 and 3 or what 4 is supposed to do?
jameslxdt
Post by jameslxdt »
3 is just a temp display, no computer, and 4 turns all functions off
Ah so 3 has no radio display?
I've been out and fixed it today. My heat shrink covering the solder connections got pierced by another connection which is why it was blowing fuses and also why the comp stayed backlit. Oops :|
But now I have the microswitch blu-tacked to the top of the steering column and it works a charm :D Think I'll definitely rip your idea of getting a spare heated rear windscreen button though - blu-tack does look a bit, uhm, tacky if you'll excuse the pun :)
So now I have average speed and a 2nd trip counter. Cool. Need to replace the computer though because half the segments in the LCD are dead. Bah. Luckily the PCB is in 2 halves so I don't have to re-do the solder job...
Had a look for the ECU wire under the bonnet too, but didn't have much luck. Peeled back the wiring tube about 9 inches but just couldn't see a single number on any of the wires - just rows of dots, and I still have no idea how I'm going to get the new wire through the bulkhead. Fancy giving me a hand one weekend in exchange for a pint or something if you're not too far away? :)
jameslxdt
Post by jameslxdt »
where abouts are you?
I'm up in Stoke, but I'm not adverse to long drives ;)
jameslxdt
Post by jameslxdt »
well im in south london, so thats just a bit too far
D'oh!
Can you remember how you worked out which wire to use? Or were yours numbered somewhere sensible unlike mine?
jameslxdt
Post by jameslxdt »
my wires were numbered :?
if you like at the the first thread about the trip computer, theres a turbo wirirng diagram and i think it shows you where that wire appears in the engine bay, theres a loom plug under the battery tray i think, its in that
jameslxdt
Post by jameslxdt »
ok, i have just looked over this wiring diagram and its no help, take the ecu out, unplug it, get a maginfying glass, the pins are numbered on the inside of the ecu plug, find the right pin, pin 32, take the back of the ecu plug off and you should then be able to easily find wire 1368 in pin 32, follow the wire back from the plug till its near the drivers side top suspension housing, then strip back the insulation and solder the wire on :P
