Hi guys my first post so thnks for letting me join. I have 2.1 td 406 that occasionally refuses to start in spite of recently being fully serviced and having the glow plugs replaced. I have been told it may have something to do with the fuel pump any ideas ?
Thanks in advance
Liam
406 2.1 TD occasional starting problem
Welcome to the nut house
When it fails to start, do you notice any difference in the noises it makes when you switch the ignition on prior to engaging the starter? Personally I haven't worked out what's what in the little symphony my 406 gives me before I start it (can you tell I'm in a good mood with mine today?), but apparently one of the whirrings is the fuel pump doing stuff which means a change in the sound (perhaps a particular whirring is missing?) could well indicate a problem with it.
Also, it's not your immobiliser kicking in is it?
