Vibrating Engine mount (FAO Jameslxdt)
Yo James!
In order to cure your lower O/S engine mount vibration you said "use Rad hose"
How does one use the Rad hose to be precise? I've half inched some radiator hose from a scapped 6, now all I need is a laymens guide on what you did
Can you help?
It is as simple as just forcing some rad hose rubber between the pin and bracket?
Can you help?
- jameslxdt
im here
cut the bush in two pieces lengthways, then into inch segments, using an assistant using a pry bar, lever the engine towards the bulkhead, push the hose in the gap on the bush, lever the engine the other way and put the hose in the gap of the bush in the other side, do the same for the bottom bush, but this is very hard as you cant get a prybar under the car with it on axle stands
- jameslxdt
on the 2.0 16v RFV, all of them, the engine mount bushes are far far too weak for the movement of the engine
Great... thanks for the how tojameslxdt wrote:im here![]()
