Pulling to the left
Pulling to the left
My steering seems to pull to the left sometimes. Not strongly, but quickly and it seems like I'm moving more to the left than I should be with the steering wheel where it it. It's as if I've just hit a small oil patch or something... It sometimes happens under braking and when going over bumps. Been getting worse for the last few times I've driven it.
My MOT warning about 6 months ago was something about a 'swivel' joint causing excessive steering play (although the tiniest steering wheel movement has an effect for me)... Could this be the cause of the problem? WTF is a swivel joint and how much am I going to have to sell to get the parts needed to fix it? (Please god let it be something I can do myself - I'm not joking about having to sell stuff!)
Could it be something perishable like a rubber "thing" between the wheels and the steering rack just decided to wear on me? I honestly have no clue whatsoever about steering
jameslxdt
Post by jameslxdt »
i think they are refering to the steering rod, about £20 from ECP, you could fit it yourself, but im sure you need a special spanner, and you will need to get the wheel alignment reset afterwards
Hmm. I really don't want to go replacing something that doesn't need replacing - I'm really skint. How can I diagnose what's actually wrong? Take the wheels and linings off and start yanking at things looking for something loose?
