Hold on, the rest of the lights work so you think it's a fuse? Did you look at the bulbs? If they're ok I think you need to check the wiring 'cos it would be mad to have a separate feed and fuse for the high level light.
Hold on, it is a Peugeot...
Brake Lights
Re: Brake Lights
Re: Brake Lights
the brake lights are a different elements to the tail lights
replace the correct bulb as a starting point
Re: Brake Lights
the pedal sensor would effect all brake lights.
1997 Honda Prelude 2.2 VTi
Re: Brake Lights
It affects all three brake lights, as I discovered when I was playing around with the switches for the cruise control...supafrisk wrote:I remember a '6 that went for test and had no brake lights, it was a sensor/switch in the driver's footwellCan't remember if it affected the high level one or not though.........
