hey im new
Creedy
hey im new
Post by Creedy »
hello all
i got my sri tubby a few months ago, its my 2nd car and is used daily. got a few mods on it.
planning on a few more in the next few months... more power + better sounds :mrgreen:
there is a small amount of rust on the rear door, at the bottom. is this normal?
cheers
Neal
Re: hey im new
Hi there Neal. The rust isn't normal, it's either been in a shunt or the drain holes are blocked and it's full of water...
So, what are the mods and what are you plannin?
Creedy
Re: hey im new
Post by Creedy »
thats what i though, my old s16 didnt rust even wen there was a bit of bare metal exposed from a stone chip.
well its lowered alot, it grinds on everything :D i belive its a cat back system (wana get a decat) with a 4" pipe out back. its fairly quite and i want it abit louder (ie like a rs turbo) has a pipecross viper filter and silcone HT leads with colder plugs, short shift kit.
buying some motorsport rims for it at weekend. and then a few power mods and little things like steering wheel etc
Re: hey im new
Welcome Neal :)
Re: hey im new
Hello Fella!
Be carefull with the mods - your engine is not that strong once you take it out of it's comfort zone :| it was put together to compete with Fords and Vauxhalls at the time and was fitted with a small low pressure turbo to assist low end torque (which it does very well) rather than go to the expense of developing an all-new 16valve unit.
It's not really for ragging about in too much unless you want to spend a *lot* on beefing things up first like the Turbo, head gasket, cooling 'system', fueling, engine mounts, .....................
Creedy
Re: hey im new
Post by Creedy »
i dont really rag it around tbh im not like that anymore plus in this day and age its hard to do so :x
im just after a meater sound from the exhuast and more of a kick from the turbo.
