Cant get OUT or IN?
- 1.6 8v
Cant get OUT or IN?
Problem folks and need the A Team to help me fix it.
The passengers rear door is closed shut and for some reason cant be opened from outside OR inside?
Anyone had this problem before at all and how have they rectifyed this issue?
All help needed please folks
Cheers
Cheers
- Site Admin & Mad Biker!
Re: Cant get OUT or IN?
Sounds like the central locking actuator has stuck. See if you can get the door card off and flick it with a screwdriver; does the lock operate on that door when you flick it manually?
- 1.6 8v
Theres no life in that door at all buddy.
Gona be one pain trying to get the door card off with the door closed but hay ho needs must i guess lol
- DaiRees
- Site Admin
Yeah the deadlock used to sieze on the rear passenger door on my D8, I used to just lock / unlock the car repeatedly until it released (sometimes took lots and lots of tries). Eventually I just stopped deadlocking it
i will probably have this problem soon
when i lock and unlock my car with the remote the drivers side rear door sumtimes fails to unlock/lock
my grampas polo has the same problem (yes a german car has a fault) the back door is locked, and because vw are tits the snib in its locked position sits flush with the surroundings so theres no point in pulling it, and because its down neither of the 2 handles work, and its not picking up the signal when the cars unlocked. I really dont know where to start if the doors not opening.
i was at my local council tip last week just getting rid of excess xmas cardboard and rubbish i left the car running because it was only going to take a few seconds,the doors were closed and again the engine was running then i heard them lock,i thought oh sh*t,and indeed they were locked.i dont know if its a fault or just purely the outside temp which was -6,i contacted the breakdown service who said it would be over an hour,i had a car which was running but locked blocking the road and i was freezing my nuts of,i borrowed a guys hammer,smashed the rear quarter passenger window,lowered the window got my son to climb in and get keys out of ignition to unlock doors,i then rang auto glass and had it replaced for a silly amount of £133.00,so the lessons learned are always take your keys out and make sure you are covered with fully comp.
ah yes the keys locking while running issue, a quarter windows always the best one to smash if you need to get in, its the least important window and cheapest to replace. But the bleeper that tells you to take the key out usually makes me do that.
[quote="FarmerPug"]ah yes the keys locking while running issue, a quarter windows always the best one to smash if you need to get in, its the least important window and cheapest to replace.
sorry have to disagree with you
if you have to bust a window its much better to bust the large side window because
a.......they are broken more often so they are more readliey avaliable so normally cheaper
b......removing/replacing the quarter window is more involed eg you have to remove the strip that seprates the windows and sometimes you have to remove the side window to replace it anyway.
but im assuming the member who has broke his window owns an estate, in an estate the rear window behind the door which im probably incorrectly calling the quarter one is the best to smash. Actually come to think of it on a saloon its probably easiest to bust open the boot and climb through the back seats.
Whatever one may be the easiest, i dont think the sunroof, or front windscreen will ever be the easiest ways to get in.
Quarter windows are harder to break & much harder to replace. Been there, got the scars
thankfully ive not been there.
- lozz
gets me why people break the glass when the get locked out of a car ?
anything can be opend with a length of sturdy wire
the coat hanger trick, ive never tried it but its probably possible as the 406s door controls are all controled by metal bars and not cables.
- DaiRees
- Site Admin
You really don't want to break that window in a 406 estate, first step in replacing that one is "remove head lining"FarmerPug wrote:but im assuming the member who has broke his window owns an estate, in an estate the rear window behind the door which im probably incorrectly calling the quarter one is the best to smash.
