PAS Pump
Re: PAS Pump
what engine is in yours?
Re: PAS Pump
Its a 2001 model 1.8 Petrol
Re: PAS Pump
iwouid take,the aux belt off and turn each pulley by hand,
feel for any roughness,
Sound travels so iwouidnt condemn the pas pump withought checking first,
might take 20mins to check but it couid save you a Few ££s
Re: PAS Pump
What ancillaries are on this belt besides the PAS Pump?
Re: PAS Pump
Alternator, air con, etcPVFCpug wrote:What ancillaries are on this belt besides the PAS Pump?
Re: PAS Pump
if the pumps are the same i have a spare one
Re: PAS Pump
Stripping it down on wednesday, so by the sounds of it its either Belt, Tensioner, PAS Pump, or alternator!
Can you get a tension roller as opposed to the full tensioner? It does sound like a bearing type noise so this is my suspision.
Re: PAS Pump
I had this, and it was the idler. I changed the idler and the tensioner and its been fine since. These would be the first things I would check, and they are quite cheap to.
I dont think your ears will be good enough to say which bit is making the noise with the engine running as it is all so close together.
Top tip. Make sure you do a diagram of the belt routing before you take it off, as it can be quite confusing to get back on.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Re: PAS Pump
Yep it was both the idle wheel and tensioner, 20 minute job all done, have to check its still running at tickover its so quiet!!!!
