Brake fluid loss
caprixpack
Brake fluid loss
Post by caprixpack »
It appears that the GTX is loosing brake fluid. Now I've been under the thing and checked all the calipers and brake lines, they are all dry and in good condition. I've also had the lower footwell trim out and the clutch master cylinder is dry. Is there any chance the slave cylinder could be leaking into the bell housing? Is there any way to check without having to remove it?
Re: Brake fluid loss
Drill a hole in the bottom of the bell housing...??
Never having played with a clutch on these I don't know but Haynes makes it look easy to remove the slave cylinder - remove air filter and all that, unclip the pipes,remove clip (if fitted), push slave cylinder in and turn it 90 degrees anticlockwise, remove.
None of your fancy concentric slave cylinders here!
I'm fairly sure there's a drain at the bottom of the bell housing, in the bottom of the cover plate (which is removable anyway).
caprixpack
Cheers, when the rain stops I'll have a look.
Not sure if this is practical, but there is a sheet metal cover over the lower part of bell housing that you can clearly see from underneath. Not sure if you can remove or at least loosen it without disturbing much else?
Edit: PS what's rain?
PeterN
Post by PeterN »
Could be leaking into the brake servo if no sign of a external leak.
