Bottom ball joints
Bottom ball joints
I have just replaced my link arms and bottom ball joints today, I recently bought off E Bay for a mere £21 a SEALEY Peugeot 405 406 407 Ball Joint Socket Set SX0271and by golly am I glad I did, not sure I would have got them out without it. I would fully recommend it.I hope this will help some of you in the fuure. Next project will be the brake discs, pads and shoes.(after thought :- I think I've put this in the wrong place, sorry )
Re: Bottom ball joints
A link would be good too
This'll do ya: http://uk.ebid.net/for-sale/sealey-peug ... googlebase (look, it's not bluddy evilbay
- lozz
inever knew they needed a tool to get them out
iguess this is another tool that will get used once,
ithink iwill stick with my lump hammer and chizel
Blue2 wrote:I have just replaced my link arms and bottom ball joints today, I recently bought off E Bay for a mere £21 a SEALEY Peugeot 405 406 407 Ball Joint Socket Set SX0271and by golly am I glad I did, not sure I would have got them out without it. I would fully recommend it.I hope this will help some of you in the fuure. Next project will be the brake discs, pads and shoes.(after thought :- I think I've put this in the wrong place, sorry )
I don't know where they get 407 from, the 407 ball joints are a completely different fit to the 405/406.
Maybe they mean the TOP balljoint Jasper??there different to the bottom ones i thinkjasper5 wrote:Blue2 wrote:I have just replaced my link arms and bottom ball joints today, I recently bought off E Bay for a mere £21 a SEALEY Peugeot 405 406 407 Ball Joint Socket Set SX0271and by golly am I glad I did, not sure I would have got them out without it. I would fully recommend it.I hope this will help some of you in the fuure. Next project will be the brake discs, pads and shoes.(after thought :- I think I've put this in the wrong place, sorry )
Yes Trem, you are correct, it is for the TOP ball joint, the top ball joint has 4 holes to fit the socket in (just had a look at mine).
I should have looked first
The bottom ball joint just knocks off with a chisel once you undo the 3 bolts holding the ball joint case to the bottom arm.
mine just fell off in bits when i undid the three torxjasper5 wrote:Yes Trem, you are correct, it is for the TOP ball joint, the top ball joint has 4 holes to fit the socket in (just had a look at mine).
I should have looked first![]()
