Apex lowering springs
Anyone ever used apex lowering springs ? I'm looking to get some for mine just not sure what make to go for any help would be great
- lozz
Re: Apex lowering springs
ive used them in the past but not on a 406,
ididnt have aproblem with Apex springs tho,
I might give them a go only wanna drop it 40mm
- lozz
iused Apex springs on a mk 2 mondeo, there prone for snapping springs like the 4o6 does with age,
they where on the car agood 2 years never had aproblem with them other than the ,coating peeling off on them,
shop round for prices if your getting some,they seem to be many acompany charging over rated prices for them,
theres some on ebay for £130 witch seems cheap
- lozz
Have you 'tried Amazon?
ithink there was some on there at a good price last time ilooked,
- lozz
Edit none on amazon,
have alook on cam skill,.
ithink there about the cheapest around for Apex,
http://www.camskill.co.uk/products.php?plid=m14b0s978p0
is there much difference between the coupe and sallon springs ???
- highlander
- PowerFlow Shill
Coupe springs are shorter to begin with, and probably a bit stiffer too. The Coupe sits a fair bit closer to the ground than the saloon/estate even from the factory.
No idea about the actual measurements though.
I am thinking about lowering the Coupe a little bit (no more than 25mm) but will only do that if it looks like the stock springs and shocks are on their way out. Got a fair few other things I need/want to do to the beast first.
We'll I can get a set of saloon APEC springs for 130 they seem ok they have all the treatmeant that normal springs have had might give it ago 50 mm front and 40 mm bk just got to watch out for speed bumps
if your spending 130 on springs would you be just as well buying coilovers from ebay? £160 then you can adjust to whatever height you instead of being bound to 30mm or whatever height u buy
Well ye suppose u got a point is there a certain set u would recommend ?
