Hi, the rear disks on my 52 plate 406tdi have been scored and will fail the MOT. I have got new disks and pads. The disk fitted fine, but the outer pad wont fit. When I took the old pad out I had to prise it as it was tight against the disk (hence the scoring).
It appears as if the whole calliper needs to move a few mm outboard.
If anybody knows the fix for this I would be very grateful as can't drive anywhere at the moment with half done brakes!!
Urgent help required regarding Rear Caliper
- 1.6 8v
- lozz
Re: Urgent help required regarding Rear Caliper
Did you push the piston on the caliper back before removing it.
- Site Admin & Mad Biker!
Undo the fluid reservoir cap under the bonnet & use a G-clamp to push the piston back in.
- markw
Perhaps the sliding mounts on the caliper have seized?
