handbrake lever change
Hi all gotta change my lever as my teeth are shot. Before I pay the scrapyard a visit is it just a simple case of 3 bolts, take off electric light switch & cable. Bobs ya uncle
2.0hdi lx 51 plate 90bhp chassis no.VF38BRHYF81371125
Re: handbrake lever change
Spooky
I've just changed mine. If yours has the adjuster at the top, it's easy, if a bit fiddly. Undo /remove the adjuster nut, undo the 4 mounting bolts, push the grommet back through the hole the cable comes through and wiggle it out. Make sure you get the cable to go round the quadrant correctly when refitting.
Just off for a test drive......
Sounds good doggy mine just won't stay clicked in when needed broken teeth a guess
All done it was the tooth on the lever that was worn. Not much but enough I suppose
