Door rubbers
Re: Door rubbers
last time i bought some they were 6p each dont know the part numbers i just went into dealer and asked "for the stupid liitle clips that hold the rubber onto the sill" and he knew exactly what i needed
- puggy
- Resident Pervert
- mjb
- Site Admin
Re: Door rubbers
nah i got a big pack off ebay (enough to last a lifetime) for about £3 inc P&P
Re: Door rubbers
.....comes high on the list (if not top of the list) of "the most annoying features of a 406"
- mjb
- Site Admin
Re: Door rubbers
After "where the f*ck is the cup holder?" and "why can't i get it in reverse?" ;)Welton wrote:.....comes high on the list (if not top of the list) of "the most annoying features of a 406"
Not forgetting "oh look all i can see out of the windscreen is my bonnet. hope i don't crash"...
Re: Door rubbers
Christ, the stuff of nightmares. Are you still getting flashbacks of that?mjb wrote:Not forgetting "oh look all i can see out of the windscreen is my bonnet. hope i don't crash"...
How about "oh look, my car's rolling backwards down that hill..."?
Re: Door rubbers
..."my clutch pedal is touching the steering wheel"....
- swiss
Re: Door rubbers
My door rubbers are held on with gaffa tape
The man with no car
Re: Door rubbers
(Evo stick
- mjb
- Site Admin
Re: Door rubbers
Happened twice remember... Frequent nightmares, especially as after the first time I've been religiously lifting the car by the bonnet to check EVERY SINGLE TIME I close the bonnet, and that didn't save me from the garage's incompetence making it happen a 2nd timesteve_earwig wrote:Christ, the stuff of nightmares. Are you still getting flashbacks of that?mjb wrote:Not forgetting "oh look all i can see out of the windscreen is my bonnet. hope i don't crash"...
Re: Door rubbers
I imagine the bonnet would just "open" in a controlled way due to the gas struts unlike a flappy bonnet with old fashioned prop.
I am probably grossly incorrect though given the air pressure under the bonnet at speed once it opens more than say 45 degrees
You must know what I mean though - without the gas struts it would twat the roof instantly
- mjb
- Site Admin
Re: Door rubbers
What gas struts? As soon as the air pressure under the bonnet caused by speed entering the radiator grille is enough to lift the bonnet enough to directly scoop up air, it's over in a fraction of a second and there's no time to react. The strut mounts on the bodywork get bent upward then the struts either pop out of the ball joints or the ball cups shatter. Remember there's enough force involved to bend the bonnet hinge mountings (hard to move these back with a 3ft breaker bar!) as well as forcing the hinges to an obtuse angle with enough force to make the aerial mount almost flush with the rest of the roofWelton wrote:I imagine the bonnet would just "open" in a controlled way due to the gas struts unlike a flappy bonnet with old fashioned prop.
On the upside, I've found the severity and suddenness of it happening probably saved my life both times since it put me into a strange trance-like calmness where I pulled over safely and accurately (before panicking). Panicking would more than likely have resulted in a bad bad accident multiple car+truck accident the first time at least (was overtaking a truck on a bend at 70mph at the time) whereas I calmly aborted the overtake, tucked in behind the truck and stuck the hazards on before slowing and putting it up the grass bank
- mjb
- Site Admin
Re: Door rubbers
christ what's happened to ebay? I used to just put '406' in the search box then browse through 'car parts', but all that's gone and you've got to mess about with check boxes and everything now??!?
- mjb
- Site Admin
Re: Door rubbers
http://shop.ebay.co.uk/?_nkw=406+sillnimike wrote:where? tell tellmjb wrote:nah i got a big pack off ebay (enough to last a lifetime) for about £3 inc P&P
Re: Door rubbers
Are you sure you're doing it right?scumbag central wrote:2,883 items found for '406'
Looky. Is this part of a competition to put as many spelling mistakes in an ebay ad as possible?
I really shouldn't keep looking on ebay, it always makes me depressed how cheap you can get stuff
