stearing wheel
- fairlight08
stearing wheel
does many one know how to get the factory stearing wheel off without setting the air bag off and getting to the nut to take the stearing wheel off as well i have no idea were to start lol
FAIRLIGHT LTD
- mjb
- Site Admin
Re: stearing wheel
At arms length with the battery disconnected for an hour previously i would guess
- HimBigChief
Re: stearing wheel
Firstly, disconnect the battery! Do not forget to do this as an airbag going off in your face is not going to leave you very pretty...
Generally on ABS steering wheels there are 2 bolts/screws, one on either side of the airbag, undo these and then the airbag usually pops out. Disconnect the wiring and then you have access to the big nut in the centre of the steering wheel. Possibly a 21mm (the one on my 309 is), so undo this and then tug hard (but not hard enough for the wheel to come back and smash you in the face) at the steering wheel as it's likely to be jammed on the end of the column quite well. You may need to take the indidcator canceller off the end of the steering wheel and onto the new boss (assuming you're fitting after-market) using circlip pliers.
The above is a general 'how to' guide and not vehicle specific so may be slightly different for 406s... Alternatively just get a Haynes manual and read the instructions in there!
- fairlight08
Re: stearing wheel
yeah got an omp boss to put on with the new stearing wheel thanks for the info had a look and can see the screws on the side
FAIRLIGHT LTD
Re: stearing wheel
Pops outHimBigChief wrote:Generally on ABS steering wheels there are 2 bolts/screws, one on either side of the airbag, undo these and then the airbag usually pops out.
You could leave the nut on the last couple of threads, thus saving on dental expenses...HimBigChief wrote: Disconnect the wiring and then you have access to the big nut in the centre of the steering wheel. Possibly a 21mm (the one on my 309 is), so undo this and then tug hard (but not hard enough for the wheel to come back and smash you in the face)!
- HimBigChief
Re: stearing wheel
Good point, that's what I tend to do, I also tend to give it a few taps with a hammer/mallet around the rim to loosen it up a bit.You could leave the nut on the last couple of threads, thus saving on dental expenses...
Pops out![]()
- fairlight08
Re: stearing wheel
also does anyone know?
once i have taken the factory stearing wheel off will that disable the rest of the air bags in my car?
and will it show on the dash that the air bag has gone off?
FAIRLIGHT LTD
Re: stearing wheel
Does anyone else know that when the D9 was developed one of the 'enhancements' was the fitting of a 4-spoke factory MAGNESIUM steering wheel
It will be lighter and stronger I imagine than many aftermarket wheels.
Here's the article http://www.cwn.org.uk/motoring/peugeot/ ... n-sale.htm
In fact I didn't know we had electronic brake force distribution talked about there too.
- mjb
- Site Admin
Re: stearing wheel
*snigger*The Intelligent Control Box (BSI) now forms part of a multiplexed network. This connects the dashboard, the onboard navigation and the car radio on the LCD display and the CD changer. All these systems communicate with each other more effectively than before
- fairlight08
- fairlight08
