I am removing the dashboard clocks on my 1998 d8 406. So far i have took off the plastic panel which encases the 3 airvents (it is the one with 3 torx screws above the steering wheel). I have also removed the 4 torx screws (2 above and two below) from the display panel. The dashboard display is still tight and i was wondering what else had to be loosened so i can pull the display out!
All help appreciated!
Help! Removing Dashboard clocks
- mjb
Re: Help! Removing Dashboard clocks
Is there another screw at the top in the centre? If not, just hit the thing a bit.. it should be loose now but it can get a bit wedged...
Perhaps the cables are tight or pinched.
- Site Admin & Mad Biker!
It's just the four screws holding the cluster in and a couple of clips. Pull it towards you from the top & it'll come free, two plugs to remove from the rear.
- swiss
It may well get a bit stuck in place... as has been said once you have the four inner screws out, giving it a thorough wiggle or maybe a jimmy with a screwdriver or suchlike may dislodge it. Taking care not to crack anything in the process of course. I'd advise against trying to knock it out with anything hammer-like, mind
Just in case you haven't done so already, pulling the steering wheel fully forward and down makes the task of extracting the cluster far, far easier ^_^
The man with no car
- jimmartin1
Cheers for the help lads, just thought it was a lil bit tight so didnt want to horse it out incase i put it in shite! a wee wigg got it out grand!
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
Glad you got it out Jim, but is it only me or does the above sentence read like a foreign language?jimmartin1 wrote: it was a lil bit tight so didnt want to horse it out incase i put it in shite! a wee wigg got it out grand!
Oh god i think I have been away too long!
Polskipugless soon to be DiscoPol
Done!DiscoPol wrote:Polskipugless soon to be DiscoPol
