Door lock problem
Door lock problem
Hi all i was just wondering if anyone can help me i have just got a new (V Reg) 406 and im having trouble with the central locking if i use the fob it locks then jumps right back up but if i lock it with the key they all lock and stay locked i can then open them with the fob but it doesnt open the drivers door i still have to use the key on that one hope that makes sense ive been looking around the forum but not really found an answer so im hoping someone could help
2000 2.0ltr HDI (90) Estate
- Site Admin & Mad Biker!
Re: Door lock problem
Could be the lock mechanism on the drivers door sticking, give it a good cleanup and re-lubricate it, if you pop the door card off you'll get to the central locking actuator which may need lubing as well.
thank you very much i will give it a go and up date you once done
Mine does the same thing now and a gain,
ijust give the drivers door card a bash with side of my hand and then itl lock,
ithink the bar for the inside door Exit handle gets stuck slightly on the foam inside the door causing this to happen on mine,
My door lock sometimes just spins right round but i cure tht with a swift slap to the door lol
they do spin round if you try to unluck them the wrong way,mrjay15 wrote:My door lock sometimes just spins right round but i cure tht with a swift slap to the door lol
its to prevent the lock being broken
put the key in the lock slightly and spray some wd40 in it
tried cleaning it up and lubing it but tht didnt work so i think i might just buy a new locking mech lol
