I'd like to test my radiator fan to make sure it works, where is the connector?
Will bridging the connector with a piece of wire activate the fan?
Matt
radiator fan
radiator fan
2000 2.0 HDI Estate GTX 90 bhp
- 1.6 8v
Re: radiator fan
Hi mate what model is it. You can test it by in plugging the temp sensor switch which is located on the right hand side of the head below the intake pipe. Once unplugged turn the ignition on and the fan should kick in full speed.
Re: radiator fan
cheers mate! its a 1999 2.0 Hdi exec, as soon as the rain lets up a bit i'll have a look
- 2.2 16v
Re: radiator fan
Don't do bridging connectors on these cars as a rule of thumb. There are some circuits / BSI or ECU paths which cannot handle 12v. If bridging feeds more current than it can handle, there's a chance of you burning either the ecu or BSI.
As pugmaster said locate the fan sensor, unplug and see. Else, the old school method, start up the car, a/c off and let it idle until temp gauge reaches 90. Fans should kick in at 90 (straight at 90 mark) for D9s and 92 (slightly passing 90 mark) for d8s
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
1996, 1.8(8v), SL ( The BEST Peugeot I've ever had. It kept me working on it, fixing it almost every day, I miss you)
Re: radiator fan
Thanks, i'll bear that in mind, i disconnected the fan temp sensor and the fan kicked in, i was just a little concerned because my aircon hasnt been working for a while and its been a year or two since i've heard the rad fan come on due to the car being hot, even throughout the latest warm spell we've been having my fan has stayed quiet and the engine temp stable so i just wanted to check everything still worked properly
