How to disable satnav?
Fuzzdog
Re: How to disable satnav?
Post by Fuzzdog »
grey wrote: These are Challengers (17 inch):
Originally placed on a Peugeot 307.
Then nope! Mine are 16".
** 2003 2.0 HDi 110 SE - a work in progress! **
grey
Post by grey »
Interesting, I thought they only made that design in 17s.
Do you have a close up/side view of your car?
benczuk
Post by benczuk »
Just been out to fiddle with my sat nav, found the thing thinking the disk was unreadable again, so nav was 'greyed' out so I would suggest you try removing the disk as a first action..
Once I had cleaned the disk I noticed you can set the nav volume to zero, so you could also try that..
There have been several discussions on here in the past including screen shots where people seem to indicate that they like the nav for the fact it shows street names as they drive along. Is there a 'passive mode' where it just runs showing your location that i cant find on my system, or do you drive everywhere with a route planned?
On the rare occasions when mine decided to work after a fashion, it would indicate street names if the radio was turned off, (though recently, the accuracy seems dropped off - by roughly 40 miles). :roll:
benczuk
Post by benczuk »
Doggy wrote:On the rare occasions when mine decided to work after a fashion, it would indicate street names if the radio was turned off, (though recently, the accuracy seems dropped off - by roughly 40 miles). :roll:
Nope, just get the date and time :(
I had this on mine until I was given a 2005/2006 Navteq disc, now I have the street name as I drive. Maybe update your disc, I can maybe send a 'sample' disc to you... :supafrisk:
benczuk
Post by benczuk »
PM'd :supafrisk:
grey wrote:Interesting, I thought they only made that design in 17s.
Peugeot only made that design in 17" - Fuzz has the 16' wheels that are very similar looking but smoother and slightly curved edges by the rim, common on 307's.
