Cruise Control
- Newbie
Cruise Control
Hi all new member here,
Just bought a 1997 406 2.0 automatic with 65k miles on the clock but can't figure out how to switch the cruise control on, i have the stalk on the left hand side (mines a lhd car as i live in Spain) but can't figure how to switch it on. I did a bit of research and it said there's a button or something near the mirrors adjuster, can anybody take a picture of what i need to look at ??? Does the 97 SV model have CC and if it hasn't why is the stalk there ??
Thanks guys
Thanks guys
Re: Cruise Control
Hello & Welcome
There should be a push-button switch, next to the headlight height adjuster, which you push to engage and push again to turn off.
- Newbie
Re: Cruise Control
Any chance of a pic of said button ??? I'm currently at work so don't have the car with me (back home middle of April) so trying to work off memory.
- mjb
Re: Cruise Control
It's got a light, a picture of a car and an arrow
- eoin27
- The Irish 406 addict
Re: Cruise Control
You cant miss it!
Hey Matt, My CC on the coupe isnt working at the mo. Is it likely to be down to that pump switch I heard about over the brake pedal?
- mjb
Re: Cruise Control
Something to note: CC requires a road speed over about 30-40mph and you must be in 3rd-5th. There are switches behind the brake and clutch pedals (just like the brake light switch) which disable the CC when the pedals are pressed. Pushing the accelerator does NOT cancel CC, but it doesn't change its target speed either.eoin27 wrote:Hey Matt, My CC on the coupe isnt working at the mo. Is it likely to be down to that pump switch I heard about over the brake pedal?
The pedal switches are common faults and if you're fiddling with them, you should definitely check your brake lights before driving
It's possible to activate the cruise control on axle stands, but use 5th and keep the speed as low as you can. Your car will scream ABS FAULT at you though
- Newbie
Re: Cruise Control
I'm not sure i have this so called switch near the headlight adjustment, would they fit the stalk even though it doesn't have it ???
- mjb
Re: Cruise Control
No... Please forgive me for the slightly condescending question, but you're not looking at a stalk for the stereo are you?stumitch wrote:I'm not sure i have this so called switch near the headlight adjustment, would they fit the stalk even though it doesn't have it ???
I'll see if I can grab a quick pic of my switch tonight if I remember while it's still light
- eoin27
Re: Cruise Control
Best just to check it out when you're at the car this evening. If its not there then take some pics and we'll look at it then.
Cheers for the tip Matt
X 1,000,000 if you are!!!
mjb wrote:but you're not looking at a stalk for the stereo are you?
- Newbie
Re: Cruise Control
Remember mines a LHD car but on the left hand side there a stalk thats been described as the CC and another one on the right hand side for the stereo (know this as it has the volume labelled on it.
Re: Cruise Control
If you set yourself up an account on ServiceBox, the cruise control diagram will show you exactly where all the bits are.
(Helpfully, it shows a LHD D8/early D9 setup, not the comm2000 stalks like wot I've got).
Either that or some helpful soul might upload it to Photobucket & post the link....
I'd do it myself, but my home desktop PC's dead at the mo. & If I try it with the laptop, I'll wind up using it as a frisbee
Re: Cruise Control
What are we talking about here? Is it the button or the stalk we want pics of?
Button (#5):
http://www.peugeotpartscatalogue.co.uk/D8C/6/65N01A.HTM
Stalk (#4):
http://www.peugeotpartscatalogue.co.uk/D8C/6/62G01A.HTM
It'll be on the same side, RHD or LHD
Edit: Appleogies for putting image tags instead of url ones
Button (#5):
Stalk (#4):
- Newbie
Re: Cruise Control
Cheers Steve i'll have a look for the button when i get back
