I don't know where to start!! pls help
Re: I don't know where to start!! pls help
did u fit a new timing belt or use the old one ?
and i think you needed to source the water leak rather than just presume it was the water pump
From above:
It would be odd to stick the old belt back, I'm not even if you can adjust an old one. However, this is by the by, if it's been turning and it still lines up it doesn't matter, in fact if it's dead a new belt would have been a waste
Still thinking connectors myself.
Sounds like a bull's eye to me...Suz83 wrote:When I took the old pump out there was evidence that there had been a water leak from there.
What constitutes "the rest"? Maybe here was what brokeSuz83 wrote:The engine ran after I had done this and I stopped it so I could put the rest of the can back together
- 1.6 8v
Thanks again,
Ok, after it ran I ajusted the tension on the Cam belt as it was a little tight, re-attached the auxillery belt and put wheel arch and wheel back on.....
I seem to remember someone else had this same sort of problem, If I remember it turned out to be something simple in the end.
Have a good look through the engine/transmission threads or do a search, I'm sure there is something somewhere.
I know you said you have fuel pressure from the lifter pump but have you checked there is fuel all the way to the injectors ?
*Risk of sudden death here* - beware lethal fuel pressures.
- 1.6 8v
Ok, the car has been to Peugeot today,
Fault codes are,
Permanent Fault. 3rd piston deactivation. Short-circuit to earth or circuit open. P1135.
Intermittent Fault. Crankshaft-camshaft synchronisation. variation in engine speed signal too sudden. P0340
Intermittent Fault. Crankshaft -camshaft sychronisation. No camshaft sensor signal P0340
Remote Intermittent fault. Brake contact signal. no communication P0571
Any opinions welcome!!
Fault codes are,
You haven't trapped a wire under something have you? That's a lot of faults...
- 1.6 8v
Not that I can see...
The garage said that the next step is to take the head off....
Do you agree?
Do you agree?
What? Are they nuts?? I'd say go back and check they put the cam sensor on right. I found this which might help http://www.petrila.net/peugeot/406/Serv ... df01k3.htm
Then I'd get the ecu tested.
Some of these intermittent codes sit on ecu's for years with no ill effect.
Incorrect timing could do that
or a loose / badly positoned sensor.
I've heard of this one before - it noramlly doesn't cause any problem.
All this needs is a bad connection or you've accidentally knocked the plug off the HP pump?Suz83 wrote:Permanent Fault. 3rd piston deactivation. Short-circuit to earth or circuit open. P1135.
