just brought a 406 lx estate 1.6 2000 reg
has i key and 2 seperate pads for opening the doors
is this a normal set up or been modified
(previouse one had just the keys and a number pad under the dash(p reg))
remotes for door
remotes for door
lambretta is the label on my scooter not my clothes
Re: remotes for door
Greetings
I think you're our first 1.6, what country are you in?
That sounds like something aftermarket, is there anything written on the pads?
my mistake too quick on the keys
should have said 1.8
remote fobs have a sticker on
no name just a number
EDIT (mjb): You probably don't want to put what could be your remote central locking code on a public forum!
ps uk birmingham based
Sounds like an aftermarket setup - the OEM remote central locking uses plips built into the keys, not separate fobs
Perhaps it was a cheaper option than fixing the original system. I suppose the bottom line is does it work ok?
thanks for the information all
yes it all works ok so will leave well enough alone
