remotes for door
silvermod
remotes for door
Post by silvermod »
just brought a 406 lx estate 1.6 2000 reg
has i key and 2 seperate pads for opening the doors
is this a normal set up or been modified
(previouse one had just the keys and a number pad under the dash(p reg))
lambretta is the label on my scooter not my clothes
Re: remotes for door
Greetings :cheesy: I think you're our first 1.6, what country are you in?
That sounds like something aftermarket, is there anything written on the pads?
silvermod
Post by silvermod »
my mistake too quick on the keys
should have said 1.8
remote fobs have a sticker on
no name just a number
EDIT (mjb): You probably don't want to put what could be your remote central locking code on a public forum! :shock:
ps uk birmingham based
Sounds like an aftermarket setup - the OEM remote central locking uses plips built into the keys, not separate fobs
Perhaps it was a cheaper option than fixing the original system. I suppose the bottom line is does it work ok?
silvermod
Post by silvermod »
thanks for the information all
yes it all works ok so will leave well enough alone
