Hi there, does anyone know what the sensor is that is located near the slam panel at the front of the engine bay near battery and air filter box please? its mounted on a small bracket of the condensor/ radiator location peg/cushion.
It has a plug connector and a little black pipe underneath from which a small hose connects to the turbo intake ducting. It is a 'denso' item but i dont know what its for or called....all i know is it might be faulty.
Cheers
danmat
406HDI 2.0 -SENSOR NAME?
Re: 406HDI 2.0 -SENSOR NAME?
it's your inlet air temperature sensor, (I believe, but ServiceBox helpfully just calls it 'SENSOR'
Item 15 above? 000019207T SENSOR £56.08 from Pug.
Try doing a search for part no. 1920 7T
HTH
HTH
Cheers for that...thats the item ok ...number 15.
I will see if i can get hold of one somewhere other than the main stealers..!!
Im sure its the boost pressure sensor, loads get broken by folks leaning on them and breaking off the tiny tube leading to the pipe.
I broke mine when i shunted my last 406, i effected a half decent repair using a Mk4 escort brake fluid resovoir pipe and some arraldite!
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
If it's atop the intercooler hose then I think it's boost presure, it's a 'Denso' sensor - Japanese
That be the one.Welly wrote:If it's atop the intercooler hose then I think it's boost presure, it's a 'Denso' sensor - Japanese
Thats the one guys...it says Denso on it..!
