Re-synching r/control
During my recent hassles getting the PP2000 to work, I disconnected the battery and since then, my remote control won't work. I've tried every variation of the instructions in the manual etc. but nothing seems to work.
I got 2 keys with the car, both of which were working, so got Mrs Doggy to put the spare 'somewhere safe'. Needless to say her chosen hidey-hole has proven utterly safe - we can't find it .:?
I didn't get the card with the code numbers on with the car, unfortunately.
I have a working PP2000 now, so believe I should/i] be able to sort it, but couldn't find how.
Any suggestions, folks?
mickeydread1122
Re: Re-synching r/control
Post by mickeydread1122 »
according to the Pug Handbook on Synchronising remote control follow this procedure :
Press the big button( with pug symbol ) until light indicator stops flashing ( i assume to be the red flashing 1 )
Release the big button , the indicator light is lit continously
Press the big button twice near the vehicle
Switch the ignition on for at least three seconds
Switch off the ignition
The remote control is now operational again. :)
it happened to me Dogslife when i changed my battery and i did that and it worked for me, however if it doesn't work for you then its time to see those specialist key programmers to programme it with the BSI unit for the remote key to work. :shock:
jasper5
Post by jasper5 »
If all else fails, PM your vin number and I'll speak to my mate at my local dealers to see what they do.
You will probably need your code, but i'll find out .
mickeydread1122
£45 from stealers to get the code and then another £90 to programme the keys :lol:
mickeydread1122 wrote:according to the Pug Handbook on Synchronising remote control follow this procedure :
Thanks, mickey, but I have a different key - no LED's
jasper5 wrote:If all else fails, PM your vin number and I'll speak to my mate at my local dealers to see what they do.
Thank you, John - you have PM
Surprised you have no LED on your remote , i take it you have checked
the battery is ok in the remote ?
dogslife wrote:I didn't get the card with the code numbers on with the car, unfortunately.
I'm pretty sure you can reprogram the car's key code with PP2000, but you do need to know the magic code which'll cost you a bomb to get. I only suspect this by looking through some of the PP2000 data files, because mine won't speak to my central locking ECU...
Question is though, have you tried changing the batteries in the key? I can't see how your car could lose the key code with a power outage, only the synchronisation data...
jasper5
Post by jasper5 »
Getting the code is a lot cheaper than you think :shock: :D
puggy wrote:Surprised you have no LED on your remote , i take it you have checked
Later D9's definetely don't have LED's
As you and Matt suggest, it could be the battery in the remote, so I'll check, but it did stop working as soon as I disconnected the car's battery.
Update: CR2016 battery, 3V. nominal, measures 3.05V. so I guess that's not it.
mjb wrote: mine won't speak to my central locking ECU...
I thought the same first time I looked for it, but I got to the page where you enter the number - think you have to select 'Initialisation' from one of the menus, without specifying which ECU.
Pug charge £25 to look it up for you :frown:
I'm going to try pouring some money down the phone to them, as jasper5 kindly suggested, and see if they'll give me the code so I can program it myself.....
Sorted! 8)
After a bit of a goooooogle, I discovered digital kaos, (which is where the guys on the coupe forum discovered the secrets of de-FAPping). There's a skicky on their site where you can post your VIN and they'll reply with the PIN code for your remote. I got an answer with 24 hours, FOC - (stealers want £25 to look it up for you). Just search for 'vin to pin'. :wink:
Once you have this, PP2000 talks you through the process of 'Learning' the key code, in a few minutes. :cheesy:
Brilliant! This is one thing I would really like to get sorted!!
Archangel
Post by Archangel »
forgive the newbie but what is PP2000 ?
Replacement !
Dealer diagnostic system clone, like this
Archangel
Post by Archangel »
aha , thx for that
Replacement !
