Does anyone have peugeot planet near me?
baurluvva
Post by baurluvva »
Hi all,
I am experiencing limp home mode in my 307 after changing a knackered turbo.
I need to plug it in to read all the fault codes and reset if poss
My question is .......
Is there anyone near Swindon Wilts that possesses pp2000 that would help me?
Beer tokens / pasties supplied :cheesy:
Re: Does anyone have peugeot planet near me?
I don't think you actually need pp for that, I think any Lexcia etc. code reader that can access the ecu can read & clear fault codes just the same.
i thought the lexia was a pp2000
Oh, don't know, I'm just saying it doesn't need to be anything expensive just to play with the codes.
baurluvva
Post by baurluvva »
Yes lexia 3 is same as pp2000 but at £130 plus I figured that if someone nearby has one I would save some money for ecusafe (need to defap the car also) :cry:
I can de-FAP your ecu file, if you send me a copy.....
jamjar1383
Post by jamjar1383 »
dogslife wrote:I can de-FAP your ecu file, if you send me a copy.....
could u explain what u mean by de-fap??? :|
d9 hdi 90 rapier estate
baurluvva
Post by baurluvva »
Thanks dogslife, I'm surethat I will take you up on your kind offer!
How do I get the file - do I need kwp2000? Or use ecu safe ?
Once obtained will I need kwp2000 to upload?
De-fap is to remove the particle filter in the exhaust (solves anti pollution fault) :)
baurluvva
Post by baurluvva »
Still need someone close by to read/rest fault codes though! Anyone?
because no ones near me i bought myself one
How old is your car? As wiggy says, if it's newer than 2004 then pretty much any OBDII code reader should be able to read and reset your codes...
its worth a try in a conventional code reader first to see if that sorts it out then the pp2000 is needed
baurluvva
Post by baurluvva »
its an 02 plate so unsure if any others work
baurluvva wrote:How do I get the file - do I need kwp2000? Or use ecu safe ?
You need kwp2000, (or Galletto 1260), to copy the file from your ecu and to download the modified version.
Ecusafe is used for modifying the file 'offline' - DO NOT LET ECUSAFE ITSELF ANYWHERE NEAR YOUR ECU :shock:
baurluvva
Post by baurluvva »
ahhhh now it makes more sense!
If I download my ecu file with kwp, and get it defapped elsewhere - I can upload modded file with kwp! Cool!
Just need someone with pp2000 to erase faults - or will detaching battery for some time wipe ecu??
