baurluvva
Posts: 21 Joined: Tue Dec 07, 2010 1:25 pm
Post
by baurluvva » Tue Dec 21, 2010 4:36 pm
Hi all,
I am experiencing limp home mode in my 307 after changing a knackered turbo.
I need to plug it in to read all the fault codes and reset if poss
My question is .......
Is there anyone near Swindon Wilts that possesses pp2000 that would help me?
Beer tokens / pasties supplied
Posts: 19813 Joined: Thu Oct 04, 2007 6:09 pm
Post
by steve_earwig » Tue Dec 21, 2010 5:28 pm
I don't think you actually need pp for that, I think any Lexcia etc. code reader that can access the ecu can read & clear fault codes just the same.
Posts: 9656 Joined: Tue Jun 01, 2010 5:42 pm
Post
by FarmerPug » Wed Dec 22, 2010 2:25 am
i thought the lexia was a pp2000
Post
by steve_earwig » Wed Dec 22, 2010 7:04 am
Oh, don't know, I'm just saying it doesn't need to be anything expensive just to play with the codes.
baurluvva
Post
by baurluvva » Wed Dec 22, 2010 8:59 am
Yes lexia 3 is same as pp2000 but at £130 plus I figured that if someone nearby has one I would save some money for ecusafe (need to defap the car also)
Posts: 10710 Joined: Mon Oct 13, 2008 11:49 pm
Post
by Doggy » Wed Dec 22, 2010 1:10 pm
I can de-FAP your ecu file, if you send me a copy.....
2003 HDi 2.2 6 -speed Exec Estate (2012-19) (also a gem)
jamjar1383
Posts: 542 Joined: Sun Mar 02, 2008 7:24 pm
Post
by jamjar1383 » Wed Dec 22, 2010 10:04 pm
dogslife wrote: I can de-FAP your ecu file, if you send me a copy.....
could u explain what u mean by de-fap???
d9 hdi 90 rapier estate
baurluvva
Post
by baurluvva » Wed Dec 22, 2010 11:24 pm
Thanks dogslife, I'm surethat I will take you up on your kind offer!
How do I get the file - do I need kwp2000? Or use ecu safe ?
Once obtained will I need kwp2000 to upload?
De-fap is to remove the particle filter in the exhaust (solves anti pollution fault)
baurluvva
Post
by baurluvva » Wed Dec 22, 2010 11:25 pm
Still need someone close by to read/rest fault codes though! Anyone?
Post
by FarmerPug » Wed Dec 22, 2010 11:54 pm
because no ones near me i bought myself one
Posts: 5377 Joined: Sat Aug 06, 2005 8:24 am
Post
by DaiRees » Thu Dec 23, 2010 10:49 am
How old is your car? As wiggy says, if it's newer than 2004 then pretty much any OBDII code reader should be able to read and reset your codes...
Playtime_Fontayne wrote: "Dai Rees Supplier of Fine Automobilia. Established 2007"
Post
by FarmerPug » Thu Dec 23, 2010 11:51 am
its worth a try in a conventional code reader first to see if that sorts it out then the pp2000 is needed
baurluvva
Post
by baurluvva » Thu Dec 23, 2010 1:04 pm
its an 02 plate so unsure if any others work
Post
by Doggy » Thu Dec 23, 2010 1:05 pm
baurluvva wrote: How do I get the file - do I need kwp2000? Or use ecu safe ?
You need kwp2000, (or Galletto 1260), to copy the file from your ecu and to download the modified version.
Ecusafe is used for modifying the file 'offline' - DO NOT LET ECUSAFE ITSELF ANYWHERE NEAR YOUR ECU
baurluvva
Post
by baurluvva » Thu Dec 23, 2010 1:59 pm
ahhhh now it makes more sense!
If I download my ecu file with kwp, and get it defapped elsewhere - I can upload modded file with kwp! Cool!
Just need someone with pp2000 to erase faults - or will detaching battery for some time wipe ecu??
