electrical i think
g7vhj
electrical i think
Post by g7vhj »
Not sure if this should be in here or engine posts.
I need help again
About 3 weeks ago i was driving to my local market and the engine died (without warning) never to restart, After waiting ages for the RACman to tow me home he did a few of the usual tests (fuses,battery)etc and also checked for fuel pump and spark at the plugs.
There was and still is no spark at the plugs and suggested that it was the double relay next to the engine managment unit, This was duly replaced £41 from pug dealer and with fingers crossed i hoped it would work alas it didn't.
should have said 2 litre petrol on a p plate.
any suggestions would be very welcome as i am finding the wifes Perodua nippa a bit small.
Oh and where would i find the coil pack as there is power getting there but nothing coming out immobilizer is ok and working.
regards Pete
P reg 2.0 ltr petrol d8
Re: electrical i think
it couid be a number of things,
you wouid be best having a diagnostic done on the car or get a handheld code reader on it,
and see if any fault codes flagup,
its hard to guess upon :(
no spark couid be :
Tdc sensor,
crank sensor,
Faulty coil pack or wiring fault,
regards lozz,
definatley worth a falt code reading session.
g7vhj
Post by g7vhj »
Thanks both for the replies.
Does it have a cut out switch up by the l/h suspension strut? (You never know...)
ive never seen the engine of a petrol 406
g7vhj
Post by g7vhj »
steve_earwig wrote:Does it have a cut out switch up by the l/h suspension strut? (You never know...)
There is a switch by the left hand strut thats about 2 cms square with a rubber cover on it but i assumed that was something to do with the alarm system.
I have checked that i am getting above 1 volt A.C on the sensor mentioned in the "Knowledge base" but it still won't start.
I haven't checked the steeper motor as i wasn't having any rough running issues, the only other concern i had with the engine was a delay when lifting the foot of the accelerator and the engine actually responding to it ( about 2 secs) but that could be normal for all i know.
Regards Pete
Almost getting to the point of getting it to a garage now.
g7vhj
Post by g7vhj »
Thanks Steve for the help, I realise now that it is a fuel cut off Switch.
Fuel is getting through but according to the rac man there is nothing coming out of the coil but there is power getting in.
Anyone in the Forest of Dean area willing to take a look?
regards pete
g7vhj
Post by g7vhj »
Still no joy with the car, Hopefully a diagnostic will be done in the next couple of days or so and then i can see where to go with it from there
thats the best thing to do, once you get the fault codes read post them up here and someone will be able to interpret them.
g7vhj
Post by g7vhj »
Just another quick question,
Does anyone elses ENGINE AUTO DIAGNOSTICS WARNING LIGHT come on when the key is put in the ignition to start the car or is it just mine?
I can't say that i noticed the light before it broke down and have only just noticed it now.
Hopefully diagnostics will be done today so fingers crossed it will be going soon.
regards Pete
:roll:
I have a picture of an engine, which I suppose is the same, it comes on with all the lights (glowplug, abs etc,) when I turn the ignition to run, it goes out last just after the engine's started.
g7vhj
Post by g7vhj »
Thanks Steve, i just wasn't sure if it was my imagination but i know it was worth asking.
Pete
have you checked the main earth point ? on a D8 its under the battery housing,
mat not be that but its worth a look at it,
also the earth for the ecu, or really all the earths which is a trouble spot in french electrics.
