Boot Light
Boot Light
does any1 know how to change the bulb in the boot under the shelf ?
the one that comes on when the boot is opened
- Site Admin & Mad Biker!
Re: Boot Light
Are you sure it's the bulb? The mercury switch is notorious for failing, you can sometime get it working by shaking the bootlid.
Re: Boot Light
no my bulb hasnt gone, i just need to know how to change it so i can connect a wire to the neg side of it for my new alarm system im fitting
is it a parcel shelf out job or can it pop off from underneith
i wanted to find out before i attempt (i have an abit of braking things if i dont know how its properly done)
i tend to just ram a screwdrived in and snap it out
Re: Boot Light
I've never changed one to be honest! I assume you just lever the lense out to get access.
Re: Boot Light
yup the lens pops out, watch the metal frame of the actual light doesnt hit the sides of the metal its in or a spark occurs and at the worst you will become mildly suprised. Then pull it out a bit further and you will have plenty of wire to add stuff onto. But for neatness, if you want to thread a wire to it its handy having the parcel shelf out, but its possible to thread it with the shelf in place. The light comes out very easy.
Re: Boot Light
you might need to uprate the fuse, as i had to do when i added led lights to the circuit.
Re: Boot Light
can u remember which is neg ? and plus ?
fuse should be ok its only to wire a trigger wire to for the alarm
Re: Boot Light
i have an idea
i have sum LED lights wired upto a wire, now i know LEDs will only work with the neg and plus wired correctly
simples
simples
Re: Boot Light
you should have a multimeter, i wouldnt do anything electrical to my car without one of them, then you will know what is +ve and what is -ve
Re: Boot Light
FarmerPug wrote:yup the lens pops out, watch the metal frame of the actual light doesnt hit the sides of the metal its in or a spark occurs and at the worst you will become mildly suprised. Then pull it out a bit further and you will have plenty of wire to add stuff onto. But for neatness, if you want to thread a wire to it its handy having the parcel shelf out, but its possible to thread it with the shelf in place. The light comes out very easy.
i`m trying out LED strip lights cos its too dull anyway , going to fit 1 strip each side , I`ll put up pics and info once its done .
Replacement !
Re: Boot Light
they are a good idea, the boots way too dark.
