Right following on from last topic where the v6 cut out on me wouldnt restart its happend again.
I solved it last time by putting a twelve volt feed direct to the fuel pump.
Tried that this time and as soon as the 12v feed is removed the pump stops and engine cuts out.
So where are all the relevant relays for the fuel injection, pump etc?
its a d8 v6
fuel injection system
Re: fuel injection system
Back to the double relay in the ECU box I reckon.
There's a crash switch reset button in the engine bay next to the front left shock mount. It's red (occasionally black), about 1 inch square. Press it and hopefully the car will start. Not had a knock to trip it? no neither had I but I was off the road for nearly a week until I discovered this swicht exists, so it's worth a try.
It may only be 12V but it's the amphere that kills you!
3Ltr V6 ES9J4S D8
3Ltr V6 ES9J4S D8
double relay has being ordered from ade bingham, should be with me today
cut off switch is fine have tried that.
next step is i wire up a relay and switch and hard wire it to the fuel pump as a tempeasure
Hello OED? I have a new word for youswampyv6 wrote:tempeasure
This "double relay" appears to actually contain 4 relays
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
I reckon with a little campaign and some solid lobbying i reckon we could get that in there, after all we all know exactly what he meantsteve_earwig wrote:Hello OED? I have a new word for youswampyv6 wrote:tempeasure![]()
hahaha
that will teach me to multi task.
giving kids breakfast, making there lunches, doing my coffee and being on the forum all at the same time!!!
yes the double relay for the v8 is in fact two pairs of relays one either side of the ecu box.
replaced both of these and all seems well!!!
now got to get it through the MOT at 10am
Glad you finally got it sorted.
swampyv6 wrote:v8
