Hi
Can someone please tell me if the wiper linkage can/should be lubricated?
My wipers, after not being used for some time, start very slowly and gradually build up to to proper working speed and are the fine until the next period of non use (a week or so).
All the Haynes manual tells me is how to remove and refit.
Regards
LB
wiper linkage
- 1.6 8v
- Location: titchy little village between Portishead and Bristol
wiper linkage
1998 406 glx, a/c, 2 lt, auto, saloon. VF38BRFVT80641922 engine XU10J4R
*** Proposed site for witty or profound statement ***
Re: wiper linkage
a bit of WD40 on the moving mechanism should do any harm ..
altho no i have never ever lubricated mine
Re: wiper linkage
Having had a wiper linkage fall off in a thunderstorm due to wear (
) I've given mine a squirt with spray grease. I'm not sure if it got where I wanted it but it's better than nothing.
If this doesn't work then the only way to be sure is to take it out, clean all the old grease out of the insides and replace it with fresh.
- 1.6 8v
Re: wiper linkage
Thanks for that, I think I'll give it a good 'ol lubing.
BTW. Thicko question time:- I've seen on this forum pugs called D8's & D9's, what's the difference and how can I tell mine?
Regards
LB
Regards
LB
Re: wiper linkage
yours is a D8 ..
the D9 is facelift . different front and boot.
altho they both have the same side doors and wings.
Re: wiper linkage
D8 = PHASE 1
D9 = PHASE 2
CHECK THIS POST OUT AS WELL FOR MORE WAYS OF TELLING WHICH IS WHICH
viewtopic.php?f=5&t=6870
D9 = PHASE 2
Re: wiper linkage
LostBloke wrote:Hi
Regards
LB
I find the best thing to do with tight wiper mechanisms is to remove the wiper arms, remove the rubbers covering the wiper arm mounts, take off the circlip off the wiper arm mount and make sure the wiper arm mount can be moved in and out easily by lubricating the pivot point....squirt WD40 down the pivot and keep moving it in and out, finish off by squirting some light oil down the pivot holes.
Refit the circlips, rubbers, and wiper arms.
- 1.6 8v
Re: wiper linkage
Thanks for your replies, I am an enlightened person.
LB
LB
