washer fuse
washer fuse
Hi again guys could anyone please tell me which fuse is for my front and rear washers It,s a 1997 estate thanks in advance ....Rob
- lozz
Re: washer fuse
is your heated rear screen working ?
daft question iknow but ive been trying to work out what fuse it couid be on yours thats blown,
as far as ican see it will be a 30amp fuse thats blown if your heated rear screen doesnt work too
have alook of this hope it helps if any
linky http://www.peugeotlogic.com/fuses/fuses406/fuses3.htm
Re: washer fuse
Thanks for the reply Lozz just checked the heated rear window and the light comes on so I surmise that fuse is ok its just that since I ground through some wires then re connected them my washers dont work and my fuel guage is showing full.
- lozz
Re: washer fuse
hi mate ipresume your car is a d8robb wrote:Thanks for the reply Lozz just checked the heated rear window and the light comes on so I surmise that fuse is ok its just that since I ground through some wires then re connected them my washers dont work and my fuel guage is showing full.
sorry im not 100% on the d8 fuse layouts, have you checked the other fuses under the bonnet?
fuel guage showing a full tank wouid be a Broken earth as a guess check the wiring and see if the earth is intact ,
- lozz
Re: washer fuse
on the d8 1997 model
windscreen washer fuse is a 10 amp located under bonnet,
Re: washer fuse
i am sure its fuse 5 under the dashboard.[also does dipped beam warning light on instrument panel]
i am also having lots of electric proplems at the moment and i cant get my washers to work but my fuse is good.
but if there is one under the bonnet i dont no what number it is as my 10 amp ones are
9 lamb senser
10
fuel pump
12 left fog lamp
13 right fog lamp
14 left main beam
15 right main beam
this is for a d8
9 lamb senser
10
fuel pump
12 left fog lamp
13 right fog lamp
14 left main beam
15 right main beam
this is for a d8
Re: washer fuse
Thanks guys its a bit of a conumdrum all the fuses are intact so it looks like an auto electrician job .It could be a strange coincidence that the washer pump packed up just before I cut through the wires , because the washers were working the day before because I changed one of the washer jets.
Re: washer fuse
Just an update the auto electrician took off the fuel guage sender wire and cleaned it hey presto it works .The washer motor had decided to pack up although it worked 9 hours before I ground through the wires big coincidence
roll on next week when my MOT is due
