Activate other features on the BSI
- atadinho
- 1.6 8v
Hi friends!
My question is: Can we activate other features on the BSI that didn't came as standard? For example ESP(although it won't work), cruise control, trip computer, speed limit alarm, etc? I heard here in Portugal that's possible, but i can't find any information... Anyone knows if it's possible or what can we activate? I'm talking about a 406 2.0 HDi D9...
Thank's!!!
Thank's!!!
Helder - Nov 1983
Peugeot 406 2.0 HDi Griffe - 2001
Ex - Opel Frontera 3P 2.5 TDS Arizona - 1998 - Powered by VM Motori!
Re: Activate other features on the BSI
Yes you can, but the functions that are listed vary depending on the age of your car:
A 1999 executive I looked at only had the speed alarm function listed.
Cruise control became an option sometime in 2001, (I think), and will only work with additional switches etc.
Many people have added the trip computer, though I do not think they changed anything in the BSI, (or perhaps necessary on later cars).
On my 2002 estate, I have added automatic rear wiper, (works along with front wipers, when reverse selected).
It has options for locking the doors above 10 kph and many others I have not tried, because there is no matching hardware, (ESP etc).
These are just my observations, the possibilities seem to change from car to car for no sensible reason. All you can do is connect yours up and see what is there.
- atadinho
- 1.6 8v
Thanks mate!!! I already have cruise control an trip computer as standard, i was interested in other functions as speed alarm, locking the doors above "x" speed, etc...dogslife wrote:Yes you can, but the functions that are listed vary depending on the age of your car:
I will try to connect up the BSI and see what's what...
Helder - Nov 1983
- OdinEidolon
I guess I need pp2k to connecto to the BSI?
I wanna see if it is possible for windows to be powered when the car has just been stopped. Mine doesn't do that for some reason.
- RayneR
i will correct some stuff,dogslife wrote:Yes you can, but the functions that are listed vary depending on the age of your car:
i added trip computer to my estate, and it was necessary enabling it on the BSI.
Cruise control can be enabled in older models too between 99-01 ( PRE-COM2000 ) and i think only with 110 bhp RHZ engines and the ones which have all the wirings and switchs pre installed .. well this is my case, i have confirmed in a garage nearby that they can do it, only needs programming on the ECU, no BSI involved ( like i suspected, this models have everything ( at least the button and stalk) connected directly to the ECU, like peugeot 806, 607, coupe, with the same ages )
The option to lock the doors above x miles would be cool, but that's not a problem, because there is always the button on the door to do it ..of course that is a feature that was made after, its not surprising not having it
Now, don't ask me about models with COM2000 , because in those i don't doubt that it will need something on the BSI side, because they are even more sophisticated ...
By the way atadinho i'm from Portugal too ! cheers mate !
Edit:
It only have power when the motor is started? and with the instrument panel turned on and the motor stopped does it work the windows ?OdinEidolon wrote:I guess I need pp2k to connecto to the BSI?
- OdinEidolon
I only have power when the key is turned on the second step (when it heats up the coils, for example). With the kay on the frst step or without the key they do not work. I do not think this is normal in a car of this price tag, even if from 2001!RayneR wrote:It only have power when the motor is started? and with the instrument panel turned on and the motor stopped does it work the windows ?OdinEidolon wrote:I guess I need pp2k to connecto to the BSI?
- RayneR
i think mine in the acessories mode( only shows battery on instrument and turns on radio and stuff ) it does work the windows ... i'll check it out ..OdinEidolon wrote:I only have power when the key is turned on the second step (when it heats up the coils, for example). With the kay on the frst step or without the key they do not work. I do not think this is normal in a car of this price tag, even if from 2001!RayneR wrote:It only have power when the motor is started? and with the instrument panel turned on and the motor stopped does it work the windows ?OdinEidolon wrote:I guess I need pp2k to connecto to the BSI?
- OdinEidolon
thanks!RayneR wrote:i think mine in the acessories mode( only shows battery on instrument and turns on radio and stuff ) it does work the windows ... i'll check it out ..
- RayneR
Hi, i now confirm that the windows work in acessories mode ... tested it ..
- OdinEidolon
Great, thanks! I'll get that activated by my Peugeot dealer.RayneR wrote:Hi, i now confirm that the windows work in acessories mode ... tested it ..
Mine do too - and for 60 seconds after you turn it off completely.
- OdinEidolon
That's what I want, I hope the stealer will do it for free.dogslife wrote:Mine do too - and for 60 seconds after you turn it off completely.
- atadinho
- 1.6 8v
Mine does that too...dogslife wrote:Mine do too - and for 60 seconds after you turn it off completely.
Helder - Nov 1983
- atadinho
- 1.6 8v
Cheers mate!!!RayneR wrote:i will correct some stuff,dogslife wrote:Yes you can, but the functions that are listed vary depending on the age of your car:
The option to lock the doors above x miles would be cool, but that's not a problem, because there is always the button on the door to do it ..of course that is a feature that was made after, its not surprising not having it![]()
By the way atadinho i'm from Portugal too ! cheers mate !![]()
Edit:
Helder - Nov 1983
- OdinEidolon
Was at the dealer's yesterday for my aircon problem, asked 'bout the BSI too. He said that modifying the BSI is a 0.8 hour job and that BSI settings have to be reinitialized at the end of the job, he thus does not suggest to do it on such an old car as the BSI might go mad.
He says before entering the BSI they should do vacuum in the system etc... it doesn't seem real to me, I see you just enter it and turn it on/off in a second!
He usually is a very honest guy, so I don't think he's trying to crap me, he just refilled the whole AC system for only 65£.
