airbag light not working (Now Fixed)
my dash airbag light is not coming on . even when i unplug the plug under the seats it still wont come on . ive checked the shunt fuse took from my spares car and still no luck ...
could the airbag control unit be at fault ? were do i even start to find this problem ?
Re: airbag light not working
First off, check if someone's removed the bulb. (Like my bro's D8, cos the airbag ecu's knackered)......
Hi Gary my airbag light was flashing so i put tape over it, then it went out permanently ,I thought the bulb had gone .i also had trouble with my heater thought it may be the slider control so I gave the centre console a smack with my hand the heater came on and so did the airbag light but it will eventually go out .Im thinking theres a loose connection in the dash or console but Im buggered if I can work out if they are related
ps jut read your MOT thread I am gonna go down the centre console route and see what lives in there
the bulb is new i replaced it. just wont come on for nothing. i even unplugged both seats and still it wont come on ..Doggy wrote:First off, check if someone's removed the bulb. (Like my bro's D8, cos the airbag ecu's knackered)......
ye thats my thought.. i'm gonna remove my airbag ecu from my spares car and swop them over when i do my front leather seats this weekend.
i have top remove the center console anyway to wire up my leccy seats ...
can a airbag control unit just be changed over from another car ? it doesnt need linking or anything does it ?
well .................. its working
fitted the airbag ECU from my spares car and bingo . the airbag light is now flashing...
- jonsowman
You're talking about the module mounted to the floor by the handbrake, under the centre console? This thing:
Was it a straight swap from the other car?
yes mate thats it ... the airbag ECU ..
yes it was a straight swap over. simply plug in
i think i know why it blew up or went faulty.
it seems theres been 2 drivers in this car. the drivers seat orange airbag wire that connects to the seat belt fastner was all fraid and snapped. so its been shorting out.
this tells me the drivers seat has been moved back and forth a lot ie 2 drivers ...
IMPORTANT - disconnect battery and wait 5 mins before messing with any airbag equipment ...
- lozz
Re: airbag light not working (Now Fixed)
Have you got the air bag light to go off mate,
or is it still flashing?
going to have a go at soldering the wiring on the seats on my pic this week,
just wondering if the light will go out if the Break in the circuit if fixed or will it need a Code/reader to reset it,
dont fancy paying £100 or more for pp2000 just for the one job
no lozz its not flashing now. when i fitted the spare ecu i just tested to see if it came on and it did. it was only flashing cos both seats were out of the car.
once i fitted seats back in and pluged them in the airbag light comes on . does its check then goes off as it should
- lozz
Excellent,
iwill have ago at fixing mine tomoz then,
got a break somewhere under one of the seats, iwill just cut out the crap conectors and solder them me thinks,
ye mine had a break. see my pic section . with drivers seat being moved back an forth a lot over the years
- lozz
Cheers gaz,
ive been out trying to fix the airbag light, Feck its cold out there,
Checked wires under seats, all have good contacts,
still light comes on, it apears the Pre-tensioners are built in with the seat belts,
so looks like ineed new seat belts perhaps,
weird car this, the pics have 2 airbag lights which is confusing,
one is showing side airbags, the other is showing air bag on steering wheel,
the side airbag one is going out as normal,
maybe the ecu has gone ??
