Just a quick one...nudge, nudge, wink, wink....
I'm thinking about fitting an MFD in my LX purely for the radio display, so I can easily see the station when I'm flicking through with the column stalk.
Not bothered about external temp or MPG readout just the radio.
Assuming the connector is already there (not checked yet) is it just a case of pop the little storage slot out and plug it in?
Retrofit fit an MFD in a D8 LX
- midsmike
Re: Retrofit fit an MFD in a D8 LX
yes it is u might have to change the radio too mate my mates just done his in his lxs
Thanks Mike,
I've currently got the standard radio/tape that came with the car, I'll give it a go now the evenings are getting lighter. If it doesn't work it's no biggy, I'll just take it out again.
- Site Admin & Mad Biker!
It should just work & if you fancy fiddling with a soldering iron you can get the temp & trip functions working as well!
just tried it and it doesn't pick up the radio. Tried all 4 positions on the little adjuster on the side. Is it a cd only thing ? If anyone has a working standard cd for a d8 with code i might be interested
i did mine got the stere didital heater controls and mfd for 30 off ebay all works but the temp
